Author Topic: replace or refurb my headlights?  (Read 1635 times)
Offline Rasco
« on: May 04, 2016, 04:42:44 pm »
mine either need a refurb via the sanding method of which there are many online tutorials, but also if  I do this what is the best way or sealing them after rework? some kind of UV clear lacquer spray? wax? clear coat? what brands etc are good.
or, as I'm a lazy git, what options are there for standard oem type replacements are HELLA any good are they just like OEM? what other cheapish brands / replacements are out there and what is the quality like?
« Last Edit: May 04, 2016, 05:10:56 pm by Rasco »
Offline mra12345
Re: replace or refurb my headlights?
« Reply #1 on: May 04, 2016, 07:23:25 pm »
Personally I'd go with the sanding option unless you like spending tons of money.  I seal with clear coat wax every so often.  Lasted almost 2 years so far doing that every 2-3 months.
Offline Lewo
« Reply #2 on: May 04, 2016, 08:21:46 pm »
The 3M sanding kits on Ebay are good.  :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #3 on: May 04, 2016, 08:46:57 pm »
Proper wet sanding with 400 grit up to 2500.
Compound and polish, then seal with something like Carpro DLUX and you'll be fine.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: May 04, 2016, 11:28:57 pm »
I used 800 1200 with cutting compound and then a polish. came out like new.  :happy2:
Offline Lewo
« Reply #5 on: May 05, 2016, 10:47:04 am »
A drill is quicker  :smiley:
Mind you, is it easy to take the lights out?
