Author Topic: Joining 3" catback to 3" downpipe  (Read 969 times)
Offline Farrie82
« on: May 06, 2016, 02:20:11 pm »
Hi all
Not long ago I have a stage 2 tune and had a 3" downpipe installed. I am now purchasing a Milltek 3" catback. My question is, how do I go about joining the catback to the downpipe?
Both joining ends of the downpipe and catback flare out to 80mm outer diameter.I just want to do a bolt on install with no welding but would also like to minimize any leaks.
Cheers.
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
Re: Joining 3" catback to 3" downpipe
« Reply #1 on: May 06, 2016, 06:50:22 pm »
eBay, you should be able to find a sleeve with clamps either end for the size you need
Instagram: stu_nc88
Offline Farrie82
« Reply #2 on: May 07, 2016, 03:40:14 am »
Yeah I've seen the sleeves and clamps that are 76mm. I just not sure if they will fit over the joint as its about 80mm.
