Author Topic: Wipers no longer working  (Read 4771 times)
Offline chrisr
« on: May 06, 2016, 07:42:10 pm »
Fitted depo headlights with hid kit, blown the wiper motor as expected, changed the motor today but still won't work, the wiper motor will work however if a direct feed is put to it.
Any ideas??
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Wipers no longer working
« Reply #1 on: May 06, 2016, 08:06:08 pm »
You need to go into vcds central electrics (9) and click into coding and then the long coding helper wheel one of the bytes will have something that says xenons with shutters off and check the box press enter on laptop and then X exit the box and then save coding and replace any blown fuses too.
Offline chrisr
« Reply #2 on: May 06, 2016, 08:26:08 pm »
Cheers I will give it a try tomorrow.
Need it sorted by Sunday at the latest as its booked in to be painted on Monday
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 06, 2016, 08:28:27 pm »
Good luck with it and let us know how you get on.
Offline doylebros
« Reply #4 on: May 06, 2016, 08:33:41 pm »
Remember the Bonnet needs to be closed when working the wipers!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 06, 2016, 08:38:20 pm »
Another stupid design from VAG  :signLOL:
Offline chrisr
« Reply #6 on: July 17, 2016, 05:33:46 pm »
Seriously starting to fall out with my golf now, got it back from paint shop today & fitted new wiper motor as it blew from fitting hid kit, the wipers still don't work even with removing hid kit and replacement motor!!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: July 17, 2016, 07:10:27 pm »
Have you closed the bonnet?.
Checked all fuses?.
Offline chrisr
« Reply #8 on: July 17, 2016, 10:32:50 pm »
Yep Checked all fuses, Checked with Vagcom that it Recognised the bonnet was closed
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: July 17, 2016, 10:49:21 pm »
Maybe you've done worse damage than you think.
Check for power to the motor?. Stalk could be faulty?.
Offline chrisr
« Reply #10 on: July 17, 2016, 11:28:29 pm »
On VCDS it says no comms with wiper motor.
I have spoke to TPS and given them the part number of the 2nd hand motor I have fitted & they say its different to the one that is listed for my car so ordered a brand new one off them just incase.
With an electrical probe there is a constant live feed there at the motor plug (Think it was a white/red wire)
One thing I did notice was on the BCM under the drivers side dash there was a white relay that was getting quite warm.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: July 17, 2016, 11:33:39 pm »
I did type bcm in my last post but deleted it as I wasn't sure if the wiper has a reply or not. Ask tps if they do a wiper relay for the car and if they do that Mayne the answer to your woes.
Offline chrisr
« Reply #12 on: July 18, 2016, 12:11:09 am »
Will give them a bell in the morning.  :happy2:
Just want the car back now as its been in Bodyshop for over a month and ran out of MOT  :grin:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: July 18, 2016, 07:05:20 am »
Good luck and  :signLOL: to MOT
Offline chrisr
« Reply #14 on: July 21, 2016, 08:47:04 pm »
Looks like the VW specialist may have found the problem with the wipers, they say it all points to the body control module.
There is a feed from the switch, the car recognises the bonnet is closed, all fuses / relays are ok.
The module is seeing the feed but not sending it to the wipers.
