Author Topic: Which engine mounts?  (Read 17701 times)
Offline Pesky jones
Re: Which engine mounts?
« Reply #45 on: May 10, 2016, 02:54:37 pm »
I have no jerking
Mine is just an audible knock. I’m going to hold off buying the mount then as it sounds like it we all have different symptoms. Grrr, wish I knew what it was!
Offline raz469
« Reply #46 on: May 10, 2016, 03:04:58 pm »
Whats subframe bushes guys?  Alk?
I hope i get my 034s soon. Will update here for all once in.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #47 on: May 10, 2016, 03:11:18 pm »
I have no jerking
Glonk Glonk that's what I used to hear but also feel.
Offline Pesky jones
« Reply #48 on: May 10, 2016, 03:15:59 pm »
Mines a singular knock, and you cant feel it. Only hear it with radio off.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #49 on: May 10, 2016, 03:19:33 pm »
Like I said to others remove it and check for play as mine was totally knackered as my video shows
Offline Pesky jones
« Reply #50 on: May 10, 2016, 03:27:02 pm »
Hm it may be worth a go at only £30.
FYI this guy had pretty much exact same issues.
http://www.vwwatercooled.com.au/forums/f15/dsg-gearbox-click-clunk-3rd-2nd-51523.html
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #51 on: May 10, 2016, 04:20:52 pm »
He never resolved it from what I can see  :signLOL:
Offline Pesky jones
« Reply #52 on: May 10, 2016, 05:42:28 pm »
No doesnt look like it lol. Im going to take mine out and check it before ordering a new one. It looks simple enough. Hope I can get the jack in under my car to support the gearbox! Lowered... only by 40ish mm but I wanna make sure the gearbox is properley supported, might be hard to do from the side. Might put it on axle stands, but then the car is tilted.... thoughts?
Offline Beej
« Reply #53 on: May 10, 2016, 05:45:29 pm »
Is there a way of checking fluid level in the box with vcds does anyone know?
Offline Pesky jones
« Reply #54 on: May 11, 2016, 10:30:29 am »
Any luck beej? I had a quick google and its not clear... I think you can tell if its been overfilled via VCDS..
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #55 on: May 11, 2016, 11:22:07 am »
You need to warm the transmission oil up to about 50 degrees and then check the oil level via vagcom. iirc
Offline Pesky jones
« Reply #56 on: May 11, 2016, 12:05:31 pm »
But how, R5gtt, how
Offline Beej
« Reply #57 on: May 11, 2016, 01:50:15 pm »
I googled for long enough until she started moaning at me! It would appear not, and that I would need to get the box up-to temp, check with vcds, remove the drain plug, and if it's over filled, some will dribble out over the internal tube to the correct level, however, if none come out, it is possible that there may not be enough in the box, or that the level is indeed correct
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #58 on: May 11, 2016, 01:52:18 pm »
I wad in vagcom the other evening and came across the transmission oil temp and how much is in the box.
Click in Vagcom 02 auto trans and go to measuring blocks or was it adaptions II Check around those and you'll find the info needed sorry have to be in it to explain further.
Offline raz469
« Reply #59 on: June 01, 2016, 01:29:58 pm »
Slight pre-revival here. Finally got some good news regarding my 034 engine mounts. So after a month n half i think they might be coming into the country!
I've had a sh*t time dealing with these mounts especially considering how little help the suppliers were. "We dont know how, were waiting on them like you". There fault or not, why pay you then, n why take my money. ****s. Without spewing anymore hate ill leave it there.
Sooo, hopefully should have these with me Friday as thats what they said to me today. Why lie if you know it's gonna be Monday, a weekend is a big deal.
Whilst i waited for the 034s, ive ordered and received:
Oem lower n upper rear sub bush,
PF insert
PF front of dogbone bush
PF front control arm bush (alk)
PF rear control arm bush
Waiting on reg g dv & cam follower, panel filter.
With the oem dogbone i ordered a new bolt and 2/4(cant member) new frame bolts with shims. I don't have any knocking yet so should i allow the shims? They so big.
Also might be difficult to compare mounts once on as will try do all the above at same time. Should i fit anything else same time? Already got sym2 tyres. Feels like a power-down upgrade.
