Author Topic: RNS510 hums  (Read 3066 times)
Offline LondonGT
RNS510 hums
« on: May 08, 2016, 05:46:08 pm »
Anyone got any ideas? I've just run diagnostics and the car threw up an aux fail code. Was working ok.
Now it hums as though a tiny fan is on and the Satnav volume won't work
Any ideas?
I need the car to transport a baby about so can't have it fail on me
Offline LondonGT
RNS510 hums
« Reply #1 on: May 08, 2016, 05:57:23 pm »
Reset to factory defaults and volume now working but the humming is still there...
I've seen some where it hums after when hot. How long does anyone know? It's 28c today and I sat with it in (engine running) for 10-15 minutes...
« Last Edit: May 08, 2016, 06:02:04 pm by LondonGT »
Offline rashg60
  • -Receive: 41
Re: RNS510 hums
« Reply #2 on: May 08, 2016, 06:26:20 pm »
I'm pretty sure they all hum after the engine has been switched off. Only for a short while though (maybe 10-15 mins). Nothing to worry about.
Has yours always done it or just started doing it now?
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline LondonGT
Re: RNS510 hums
« Reply #3 on: May 08, 2016, 06:28:53 pm »
Just started now, well so far as I've noticed...
Will go check in an hour I guess
Offline LondonGT
Re: RNS510 hums
« Reply #4 on: May 08, 2016, 07:47:19 pm »
Still doing it so I pulled the fuse...
Offline rashg60
  • -Receive: 41
Re: RNS510 hums
« Reply #5 on: May 08, 2016, 08:25:59 pm »
OK it shouldn't be doing it after an hour definitely.
Have you upgraded your can gateway?
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
Mercedes CLS 320 V6
Offline shoaybmakda
  • -Receive: 54
Re: RNS510 hums
« Reply #6 on: May 08, 2016, 08:42:58 pm »
As @rashg60 said might be can gateway related? Mine hums too but after about 5 mins max it stops. Mines a version P RNS510 if that helps
Offline LondonGT
RNS510 hums
« Reply #7 on: May 08, 2016, 09:03:52 pm »
It's been fine until today and been in there over a year. A bit weird really, I'm hoping it's just down to the weather.
The only thing I keep getting is this
Navigation
Part #: 1T0035680P
Component: RNS-MID
Coding: 04000402040000000005 (hex)
Fault codes:
03138 Input AUX IN
Radio
Part #: 1T0035680P
Component: RNS-MID
Fault codes:
03138 Input AUX IN
Thanks for your help so far, any ideas if this could make it odd? It's an upgrade not factory fit.
Offline rashg60
  • -Receive: 41
Re: RNS510 hums
« Reply #8 on: May 09, 2016, 09:34:17 am »
@RetroRaz any ideas with this?
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
Mercedes CLS 320 V6
Offline john87
  • -Receive: 53
Re: RNS510 hums
« Reply #9 on: May 20, 2016, 11:17:16 pm »
The RNS510's have a cooling fan, mines runs for a good 10 minutes sometimes after I turn the car off. Must be normal.. you should hear the fan in the mk7 headunits, it's even louder! Unless what I was hearing was an electric coolant pump seeing as it was an R  :confused:
