Author Topic: Turbo Lag  (Read 8595 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Turbo Lag
« on: May 08, 2016, 08:04:11 pm »
Wow, in all the 150 billion miles the car has done, I've never experienced Turbo lag like this :(
I've recently serviced it, with new plugs, Oil, Filter air etc.
No errors codes, but very laggy, then full power and strong.
I haven't checked Cam Follower yet, but replaced around 10k ago.
Still has original turbo in 158k, perhaps dieing? Bless her. :(
Offline shoaybmakda
  • -Receive: 54
Re: Turbo Lag
« Reply #1 on: May 08, 2016, 08:10:26 pm »
Diverter valve maybe?
Offline rashg60
  • -Receive: 41
Re: Turbo Lag
« Reply #2 on: May 08, 2016, 08:31:44 pm »
I'd say check the DV too - I've also experienced turbo lag and a nice new Reg G soon sorted that problem out for a mere £40 or so.
PS @shoaybmakda I've lost your number - please text me or summat.
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #3 on: May 08, 2016, 09:11:35 pm »
I had this ^^^ torn apart and intermittent boost.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: Turbo Lag
« Reply #4 on: May 09, 2016, 05:55:59 am »
I have my spare revision G dv on ebay at the mo item number 301951644034
If you find out yours if torn you can have it for £17 delivered, pm me if so  :smiley:
Offline Farrie82
Re: Turbo Lag
« Reply #5 on: May 09, 2016, 06:33:29 am »
DV fix is an easy one. I installed the GFB DV+. Super easy install! Check it out
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Turbo Lag
« Reply #6 on: May 09, 2016, 09:02:02 am »
If you are getting full power in higher rpm then it may not be the DV....... Worth checking it though, alog with checking pipes for signs of leakage.... after that a datalogging session on VCDS would be the next step
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #7 on: May 10, 2016, 11:24:14 am »
Thanks for the replies, I've replaced the DV more times than I can count, there's a Rev D in there now as I was sick of swapping the diaphragm Rev G's out, perhaps I've melted the plastic piston, lol.
It pulls well midrange, very laggy low down, where as it's always been ready to go at low revs, its caught me out a few times now... Possibly pipework... Think it needs good look over, Dv, pipework, cam follower, real time scan...
Noticeably this has only started since I did the last oil change a couple of hundred miles ago... No oil leak, oil level fine... Hmm.
Re: Turbo Lag
« Reply #8 on: May 10, 2016, 12:07:08 pm »
Any oil seepages from the intercooler pipes?  You normally get more noise from the turbo than usual if some boost is blowing by an O-ring.
Rev Ds are reputed to leak, so could be time to upgrade to the GFB DV+.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #9 on: May 13, 2016, 12:18:21 pm »
Got the car in the Air atm, diverter valve out, Rev D, can't really tell if it's busted tbh, the piston moves in and out, is there any other way?
Re:  Oil seepeage, yeah there is, check out this image:
Not a lot of oil but certainly some, the seals have never been replaced to my knowledge in 155k, but they aren't split, I guess any oil marks indicates it is leaking though...
Anyone know a part number for the seals?  Cheers
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #10 on: May 13, 2016, 12:47:22 pm »
Seal: 3C0145117H
I think the Hose is: 1K0 145 832 E and comes with the Seals, so might worth buying the Hose?
Re-scanned it and there was an error code, the usual P0299, which can mean pipework / DV or dieing Turbo (eek)
1 Fault Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
               P0299 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 246350 km
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Turbo Lag
« Reply #11 on: May 13, 2016, 12:52:22 pm »
Underboost code. Can't view the images in work but if you have oily deposits then you are leaking boost. Would be a good place to start!
Rev D won't be busted unless the solenoid is failed, but then you would have a code relating to the DV
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #12 on: May 13, 2016, 01:29:16 pm »
Thanks mate, I've had the same code before and each time it was the DV split (RevG), which is why I went with the RevD.
Think it's probably wise to grab new intercooler hose + DV and go from there.
Actually, are there any benefits to aftermarket intercooler hosing? The Silicon ones?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #13 on: May 13, 2016, 01:31:35 pm »
Does it come with a free million mile warranty? :jumpmove:
Seriously though, how many miles has it done mate, was is it in a K04?  I'll probably take it mate, if you're able to send out, I'll PM you bud.
Re: Turbo Lag
« Reply #14 on: May 13, 2016, 01:47:18 pm »
Can't see the pics either but I'm guessing it's a tidy little leak!
Yeah one benefit is getting rid of those leaky connections!  Unfortunately you need to upgrade the intercooler in order to delete two of them.
The biggest leak seems to come from the metal discharge pipe, on mine at least.  Thanks to VW's useless engine mounts, there's a lot of movement and it wears out the hose clip, the O ring and the tangs on the metal part of the hose.  I replaced the O ring and clip for that pipe and all was good for a month or so, then it started leaking again.  So for that reason I've gone for an aftermarket discharge pipe which does away with the silly clips / O rings.
