Author Topic: Turbo Lag  (Read 8588 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #15 on: May 13, 2016, 03:06:01 pm »
From looking at the picture it's leak and doesn't look fresh but has leaked over time.
It's a very good idea to do away with these silly designed piping and go for some silicone alternatives as recommended above.
I'll certainly do the same once the Fmic of my choice is going to be fitted.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Turbo Lag
« Reply #16 on: May 13, 2016, 03:10:21 pm »
Think I'll just go OEM if the Intercooler needs to be done too.
Yeah, the Leak seems old and to be coming from underneath the metal / pipe junction of the Hose at the Turbo side, defo getting the hose too.
1K0 145 832E -£22.99 delivered Comes with the O-Rings so may as well.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #17 on: May 13, 2016, 03:18:30 pm »
So, just to confirm, that I can't just use something like this with the OEM intercooler setup?
LINK
 :party:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #18 on: May 13, 2016, 03:20:18 pm »
No the intercooler doesn't need to be replaced but I'm sure the ends of both RHS IC and joining pipe need to be hack sawed off but not a big issue there as a decent set of mikalor super clamps will certainly hold the new pipe in place.
Cheap enough part tbh so which ever route you take will be okay.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #19 on: May 13, 2016, 03:23:31 pm »
LINK
 :party:
If they are the correct ones for the tfsi then why not. I'm sure I've seen those for the 180 bhp tt ?
Just seen the link and they'll be fine although I'm not keen on red myself.
Still need new O rings.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #20 on: May 13, 2016, 03:34:49 pm »
Good point, think I'll just OEM this time, it is a fault finding exercise after-all, lol.
Re: Turbo Lag
« Reply #21 on: May 13, 2016, 03:36:09 pm »
They are just silicon replacements for the OEM rubber hoses, which themselves are fine, it's just the stupid O-ring / clips that's the problem.   The silicon ones still have those!
If you're going OEM for an intercooler, the old aluminium S3 one or MK6 R are good upgrades and plug and play.  Neither have the O ring & clip connections!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #22 on: May 13, 2016, 03:40:32 pm »
Maybe a good idea lol
I'll definitely keep those in mind if cheaper than an after market one with piping and hose clamps which I doubt but a lot more hassle to fit on than oem.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: Turbo Lag
« Reply #23 on: May 16, 2016, 06:24:50 pm »
Just for future on-lookers, the new 1K0 145 832E solved it, swapped out tonight, replaced old DV, cleared fault, took it for a long'ish spirited ride, no errors :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Turbo Lag
« Reply #24 on: May 16, 2016, 09:22:34 pm »
Thanks for the update Scottymon ans glad you've sorted the issue out  :smiley:
Re: Turbo Lag
« Reply #25 on: May 17, 2016, 09:06:04 am »
Nice one.  Good price for that hose.  It's getting on for 4x that from the stealer!
