Author Topic: Rear Window Squeeks When Opening/Closing  (Read 1446 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: May 09, 2016, 03:07:18 pm »
Noticed my window is squeeking when closing and opening.
Anything I can oil or grease without having to remove door skin?
Re: Rear Window Squeeks When Opening/Closing
« Reply #1 on: May 09, 2016, 03:11:41 pm »
Occasionally my front windows hit a patch of resistance and go back down again instead of up!  Common problem.  Soaking the rubber window channels with Silicon spray (not WD40) usually fixes that one, so squeaks would probably be solved by the same method.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: May 09, 2016, 03:16:57 pm »
As pudding says silicone spray will resolve this issue  :happy2:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: May 09, 2016, 03:35:10 pm »
I do actually have a couple cans of silicone spray there.
So I just soak the felt like rubber strips on the window bottom? Do I have to rinse or wipe them after?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: May 09, 2016, 03:46:24 pm »
No lukemk5gti just soak them and you're done. try feed it with a straw down the runners as I did when I first bought my gti and had this issue.
« Reply #5 on: May 09, 2016, 04:00:44 pm »
Yeah that /\.   Spray loads of it into the 'U' section rubber channels and wind the windows up and down a few times.   It's messy but nothing a microfiber cloth won't wipe off afterwards!
