Author Topic: 2.0 TFSI baffled sump - balance shaft removal - oil surge issue  (Read 1973 times)
Offline The Wanderer
Hi Chaps
              Does anyone know of anywhere that does a baffled sump for the 2.0TFSI (forge only do one for the 1.8L) ??
              Has anyone had any oil surge issues once the balance shafts have been removed ??
              Any info greatly appreciated
              thanks in advance
Offline DANBOY66
  • -Given: 41
Re: 2.0 TFSI baffled sump - balance shaft removal - oil surge issue
« Reply #1 on: May 10, 2016, 03:48:11 pm »
you need to speak to @vRSAlex  from aks tunning
he will make you a sump and he sells the balance shaft removal pumps so he should have some good info for you
Dan..
« Reply #2 on: May 10, 2016, 07:07:55 pm »
Top man thanks !!
Interestingly the tuners I have spoken to previously have said there have been no issues with oil surge on the 2.0 TSFI with the shafts deleted. I personally cant get my head around that if the 1.8T did have those issues without a baffled sump.
