Author Topic: Headlights - Keep getting flashed at  (Read 5728 times)
Offline Cadders96
« on: May 11, 2016, 09:31:46 am »
I keep getting flashed at during the night with my dipped beams which have a HID Kit installed by the previous owner, not too sure what they are but I believe they are 55W 8000K, I've been reading through the forum regarding this and I am not too sure what I should be doing if I am honest. Even my friends when I go driving about with says my dipped beams are too bright whenever I am behind him. Could someone tell what I should do about it, have a look at the picture below.
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Headlights - Keep getting flashed at
« Reply #1 on: May 11, 2016, 09:32:55 am »
Take them out, chuck them in the bin, then fit regular bulbs
Offline Cadders96
« Reply #2 on: May 11, 2016, 09:45:02 am »
And why would you say that? The problem is I like the colour of the headlights
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: May 11, 2016, 09:59:18 am »
Because you have a cheap Chinese copy of Xenon headlights, that are not designed to work in a reflector type lense.
The reason you get flashed is because you have absolutely no beam pattern and might as well be driving with your main beams on, as that's how it will appear to other motorists. Take them off and bin them or buy some aftermarket projector type headlights instead.....
Or do it properly and buy genuine Xenon headlights and retrofit them to your car.
Offline Cadders96
« Reply #4 on: May 11, 2016, 10:06:08 am »
Ahhh right, I see what you mean. Another question would Depo Headlights be suitable for HIDs? something like these
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 11, 2016, 10:18:23 am »
take them out ad your blinding other road users  :stupid:
Get depo ones like most of us have and fit your xenon kit into them hob done. look at my signiture I have depos fitted.
Offline xjay1337
  • -Receive: 377
« Reply #6 on: May 11, 2016, 10:27:31 am »
yes this.
If you buy Depo projectors you should be OK if they are aligned.
Offline Cadders96
« Reply #7 on: May 11, 2016, 10:45:40 am »
Okay cheers guys I shall get it sorted ASAP, I'll take them out and put them back in when I get Depo Headlights.
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline Cadders96
« Reply #8 on: May 12, 2016, 08:53:36 am »
Planning to buy Depo headlights at the end of the month or beginning of next month, going to get Depo Projector Headlights. Should I keep the HID kit I have at the moment or get a different set of HID kit? If so could you recommend me some.
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: May 12, 2016, 09:08:27 am »
If you want to get another one, look at hids direct, they do a 35w h7 bulbs with the ballasts for around £40
Sent from my SM-G928F using Tapatalk
Offline Cadders96
« Reply #10 on: May 13, 2016, 09:11:55 am »
I'm assuming the Deop Headlamps are plug and play, the only issue would be to get Xenon- No Shutters coded in?
18" Monzas
Tinted Windows
HID Foglights
GFB DV+
Pre-Cat Delete
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: May 13, 2016, 02:01:24 pm »
Yes thats correct
Offline shaunnorris7
  • -Given: 18
  • 2008 GT TDI
« Reply #12 on: May 13, 2016, 07:36:11 pm »
If there your headlights in the image there not Chinese fakes! They are genuine as it has the VW logo covering the dipped beam bulb. Mine had replica ones of yours on it when I bought it and they were similar but no VW logo.
The reason everyone is flashing you is because you can't really use HID's with standard headlights like these. Though you can now buy anti-glare kits which are supposed to work ok but I haven't ever read a review on them.
Ideally for HID kits you want projector style headlights (ie. Depo's) and they should work fine.
I changed my GTI reps to depo's but changing back to genuine GTI ones with good bulbs as tired so many HID kits and they all gother water in somewhere and stopped working. No matter how much tape etc I wrapped the connections in.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: May 13, 2016, 08:16:07 pm »
They give you rubber grommets to prevent any water seepage into the lights and you're meant to drill a 22mm hole into the rear lamp cover where the wiring go through and then the rubber grommet seals the hole.
  • -Given: 18
  • 2008 GT TDI
« Reply #14 on: May 13, 2016, 08:20:42 pm »
Yeah I know but I'm talking about the ballast connections..
