Author Topic: Headlights - Keep getting flashed at  (Read 7839 times)
Offline akbarirfan
  • -Given: 81
Re: Headlights - Keep getting flashed at
« Reply #15 on: May 13, 2016, 08:40:58 pm »
Should be plug and play, you may also need to do the 6 O'clock mod on the bulb bases.
« Reply #16 on: May 13, 2016, 09:29:40 pm »
I put hid kit in mine and took it straight back out for the reasons you are having.
Put good bulbs back in and you will be fine
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: May 13, 2016, 09:35:03 pm »
They give you rubber grommets to prevent any water seepage into the lights and you're meant to drill a 22mm hole into the rear lamp cover where the wiring go through and then the rubber grommet seals the hole.
Yeah I know but I'm talking about the ballast connections..
Not had an issue with them even after a heavy rain fall. car wash. must be lucky I guess.
