Author Topic: Dsg paddles explanation  (Read 3154 times)
Offline oisinc
« on: May 11, 2016, 07:59:02 pm »
So I'm looking at the dsg paddles and one has a - and one has a +.
The one with the + also has "off" written below it..
What is the off for???
Offline v4rley
  • -Receive: 104
Re: Dsg paddles explanation
« Reply #1 on: May 11, 2016, 08:08:07 pm »
Is bugged me too. Guess you got an early model 05-06? It seems that the later models also have this on the OEM paddles. I never did discover why..
Later OEM paddles
Offline Beej
« Reply #2 on: May 11, 2016, 08:25:42 pm »
The off is if you are driving in 'D' and then pull on one of the paddles to shift gear yourself, it will show on the screen the gear number you are then in like it would in manual mode, if you pull on the +/'off' lever and hold it for 2 seconds, it will switch back to 'D' without having to wait the given 20 seconds or so for it to revert back itself
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 11, 2016, 08:28:09 pm »
Good explanation Beej  :happy2:
Offline Beej
« Reply #4 on: May 11, 2016, 08:30:45 pm »
No problem, hope it was easy enough to understand!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 11, 2016, 10:35:27 pm »
I already new that but easy enough for whoever doesn't know and reads it  :happy2:
Offline Paradox1
  • -Given: 41
« Reply #6 on: May 12, 2016, 07:24:16 am »
Thanks for that. I keep putting it in stick manual then back in D to get it working auto again
Offline raz469
« Reply #7 on: May 12, 2016, 11:49:16 am »
^^same.
Thanks beej. I wonder how long i would of driven around without this gem.
Offline Lewo
« Reply #8 on: May 12, 2016, 07:21:38 pm »
Another thanks beej, never knew that!  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: May 12, 2016, 10:06:12 pm »
Tried it today, thanks beej
Sent from my SM-G928F using Tapatalk
Offline Beej
« Reply #10 on: May 13, 2016, 01:44:17 pm »
No problem guys, happy to help when I can!
Offline oisinc
« Reply #11 on: May 13, 2016, 07:00:27 pm »
Cheers Beej!
Thought it might turn the paddles off or something :D
