Author Topic: My new gti  (Read 7877 times)
Offline moy24
My new gti
« on: May 12, 2016, 07:38:21 pm »
Just brought a new gti. I wanted to modify it a bit any ideas and when I checked for fault codes one came up reading sensor reference voltage A low what is it . No lights are on dash and car drives perfect so it's not affecting the car but what is it[/URL[URL=http://s945.photobucket.com/user/moy786/media/Mobile%20Uploads/5734bf482bac6_1_kindlephoto-9947802.jpg.html][/URL[URL=http://s945.photobucket.com/user/moy786/media/Mobile%20Uploads/5734bf1331cb4_1_kindlephoto-9857552.jpg.html][/URL[URL=http://s945.photobucket.com/user/moy786/media/Mobile%20Uploads/5734bf903e4f8_1_kindlephoto-9776650.jpg.html][/URL
« Last Edit: June 02, 2016, 04:06:31 pm by moy24 »
Offline moy24
Re: My new gti modifications idea needed
« Reply #1 on: May 13, 2016, 07:36:14 pm »
Any modifications idea or advice on what to do to make it better let me no.
« Reply #2 on: May 13, 2016, 09:32:33 pm »
Have a read through the members ride section and you will get loads of ideas :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 13, 2016, 09:36:26 pm »
headlights and wheels for starters  :P
Offline Octoparrot
  • -Receive: 102
« Reply #4 on: May 13, 2016, 10:21:04 pm »
I quite like the wheels, looks a fine example. My advice would be to carry out any preventative maintenance items first before you start modding it. Full service, HPFP cam follower etc. Good luck with the car!  :happy2:
Offline shoaybmakda
  • -Receive: 54
« Reply #5 on: May 13, 2016, 10:36:05 pm »
I agree with @Octoparrot carry out maintanence work first like PCV, diverter valve, cam follower, servicing etc. No idea what your fault is but if you have a look on here for the fault code you might get an idea once you get the fault code via VCDS:
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Then would be a good base to mod - If you go for cosmetics externally my choice would be to colour code the black plastics and maybe change the wheels if you don't like the look. Internally you could do things like head unit upgrade to RNS510 (With canbus change if required) and highline dash upgrade and MFSW buttons.
Performance mods a good start would be stage 1 (R-Tech are one of the most recommended guys for remaps) and a exhaust system (BCS and Miltek seem to be the most preferred options I found) the rest is up to you how far you want to go  :wink:
Welcome to the forum and enjoy your slippery slope of modding your GTI!  :wink:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 13, 2016, 10:38:33 pm »
Excellent point with the maintenance side of things first  :happy2: expecially that fuel pump cam follower.
Offline moy24
« Reply #7 on: May 14, 2016, 05:57:15 am »
Car got been serviced last month by audi. But I don't no alliance t about the common things I need to replace like cam followers till now and pcv etc what else do I need to check any advice will be appreciated.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: May 14, 2016, 03:22:39 pm »
Divertor valve as yours could look like this.  :surprised:
fits around the right hand side if the engine on the turbo at the rear
Offline moy24
« Reply #9 on: May 14, 2016, 07:04:57 pm »
Thanks mate for the advice what else should I check or replace as this is my first golf gti
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: May 14, 2016, 07:46:55 pm »
My favourite item or items are gear box mount check and replace if required. usually tell when your car judders when taking up drive but could also be the dog mount under the car so that should be checked too.
Spark plugs BKR7EIX platinum if the vw haven't replaced the standard ones on the service as this is usually replaced on a full service only. if they are okay leave them. console bushes are front wishbone rear bushes and could also be torn so good idea to check those or have them checked.
Mine were torn so replaced with after market polyurethane bushes. now feels more solid and less bouncy and a lot less like the cars in flight.
« Last Edit: May 14, 2016, 09:17:07 pm by r5gtt »
Offline moy24
« Reply #11 on: May 14, 2016, 09:04:03 pm »
Has anyone got part number for diverter valve, pcv, cam follower and can you recommend where to buy it from any links will be great.
Offline shoaybmakda
  • -Receive: 54
« Reply #12 on: May 14, 2016, 10:22:36 pm »
TPS is probably your best bet mate - if you ask them for those parts they SHOULD be able to help (my local TPS however sent me a sun visor clip instead of a cam follower though after they originally thought i was talking about a cam belt kit and they had never heard of cam follower  :grin: )
Offline moy24
« Reply #13 on: May 15, 2016, 07:00:51 pm »
TPS is trade only so won't help me.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: May 15, 2016, 09:16:21 pm »
type gti mk5 and then what your lookimg for* example golf gti pcv or divertor valve into Google.
cam follower cam be purchased from ebay KMS Bradford street Birmingham as per ebay site. here's the number to type into ebay>>>  401102114558
£25.09 for that.
Ask the forum what part number and then type this into ebay. 》》》 golf gti mk5 pcv  or 151893346443
KMS divertor valve ebay  》》》 191497886936
phew  :phew:
« Last Edit: May 15, 2016, 09:23:15 pm by r5gtt »
