Author Topic: My new gti  (Read 7867 times)
Offline moy24
Re: My new gti modifications idea needed
« Reply #15 on: May 15, 2016, 09:39:31 pm »
type gti mk5 and then what your lookimg for* example golf gti pcv or divertor valve into Google.
cam follower cam be purchased from ebay KMS Bradford street Birmingham as per ebay site. here's the number to type into ebay>>>  401102114558
£25.09 for that.
Thanks just wanted to make sure I get right parts
Ask the forum what part number and then type this into ebay. 》》》 golf gti mk5 pcv  or 151893346443
KMS divertor valve ebay  》》》 191497886936
phew  :phew:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: May 15, 2016, 10:22:41 pm »
Offline moy24
« Reply #17 on: June 02, 2016, 10:23:24 am »
Got the cambelt done so not to worry about it now. Will have a look at diverter valve and can follower in a week time due to work. What does sensor reference voltage A circuit low mean as that's the code came up with a diagnostic tool but car seems to be fine so can't figure out what it is. Had a look on Google but can't get much information.
Offline Grunt894
« Reply #18 on: June 02, 2016, 10:58:06 am »
I would recommend the GFB DV+ it is a little bit more expensive than oem but it works and it's reliable
http://www.ebay.co.uk/itm/271664459868?redirect=mobile
Offline Grunt894
« Reply #19 on: June 02, 2016, 11:02:51 am »
I would also recommend a replacement filter if your not going to go for full on induction kit. I put a Ramair one in mine and seems to do the job
http://www.ebay.co.uk/itm/2-0-TFSI-Ramair-Performance-Replacement-Foam-Panel-Filter-GTi-MK5-A3-S3-Leon-VW-/271742108089?fits=Model%3AGolf%7CPlat_Gen%3AMK+V&hash=item3f451781b9:g:HHYAAOSwA4dWMMwi
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #20 on: June 02, 2016, 11:13:26 am »
My build thread so far - http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
My how to guide on replacing your diverter valve - http://www.mk5golfgti.co.uk/forum/index.php/topic,87824.msg893078.html#msg893078
My detailing guide - http://www.mk5golfgti.co.uk/forum/index.php/topic,89106.msg902491.html#msg902491
Shameless self promotion? Honestly, when I bought my car at first I didn't know where to start and the best thing I found was a similar guide from a member who was on here many years ago!
Good luck!
Offline ChrisGT
« Reply #21 on: June 02, 2016, 12:16:01 pm »
As the others have said, the maintenance stuff like check DV valve PCV etc. Mind and check the cabin pollen filter, under/behind glove box as it is often not changed and gets pretty minging!
Other good cheap mods are things like interior LED's, LED number plate lights, Stubby aerial, seat adjustment badge inserts...
More expensive stuff like exhausts, bumper/trim colour coded or even go for r32 rear bumper and exhaust, remap, air intake, get it detailed, upgrade engine mounts... depends what you want from the car...
There are literally a million things you can do to mod a car, have a look through the other members rides threads and see what you like and don't like.
Chris
Offline moy24
Re: My new gti
« Reply #22 on: June 02, 2016, 04:07:59 pm »
Thanks for everyone's input anyone has idea what the fault is voltage A circuit low
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: My new gti
« Reply #23 on: June 02, 2016, 04:15:55 pm »
What's the actual error code?
Offline moy24
Re: My new gti
« Reply #24 on: June 02, 2016, 04:29:21 pm »
Basically it reads P0642 sensor reference voltage A circuit low
Offline bad devotions
  • -Given: 19
Re: My new gti
« Reply #25 on: June 02, 2016, 09:04:18 pm »
damn! i've had my car a while and never thought about the DV... :S clearly i doin't spend enough time on here! I'll have to make a purchase me thinks!
Offline Gmac
  • -Given: 30
Re: My new gti
« Reply #26 on: June 03, 2016, 06:03:49 am »
I think someone already suggested you go to rosstech wiki...
Anyway, welcome.  A bit of self reading always helps...
Here is the rosstech wiki page and your fault code....I would get the car scanned using a proper version of vcds (formally vagcom) and then clear the code.  Drive it for a few days and then rescan.  If the fault code comes back then start looking at possible solutions.  You'll probably find that it doesn't come back though....If you haven't got access to vcds that you know of then put a thread up where you are and if there is anyone local to you that has vcds and would be willing to help.  I have vcds and have scanned a number of cars locally, saving them £60 approx to go to a main dealer and get a 'diagnostic check'
HTH. (Hope that helps)
http://wiki.ross-tech.com/wiki/index.php/17026/P0642/001602
Offline inch_speller
« Reply #27 on: June 03, 2016, 08:27:06 pm »
Good filter and I used the Make an Offer on delivery got it for £24.00
Offline moy24
Re: My new gti
« Reply #28 on: June 16, 2016, 02:49:51 pm »
Tried to remove my diverter valve can't seem to get to the 3rd bolt might have to get it done at garage.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: My new gti
« Reply #29 on: June 16, 2016, 02:54:55 pm »
It's just cooked on with grease and threadlock. You really need the right tools. I had about 4 attachments on my spanner to get enough leverage!
