Author Topic: HELPPP  (Read 2647 times)
Offline Blakescarth
HELPPP
« on: May 15, 2016, 08:30:06 pm »
 had throttle body changed This morning drove fine all day until just now took it past 3K and it died out went it to limp mode no power at all pulled over took key out started again was fine went up to 3K again and exactly the same can anyone she'd any light
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: HELPPP
« Reply #1 on: May 15, 2016, 09:01:22 pm »
Was it aligned?
Re: HELPPP
« Reply #2 on: May 15, 2016, 11:27:24 pm »
Was it aligned?
This ^^...
Also was it a new or second hand item?
Offline Blakescarth
Re: HELPPP
« Reply #3 on: May 15, 2016, 11:52:12 pm »
Was all dine perfect happened hours after it was fitted been advised cleaning turbo vanes
Offline slix
  • -Receive: 38
Re: HELPPP
« Reply #4 on: May 16, 2016, 01:06:41 am »
I'd still point to the "new" TB. As you didn't have this problem before did you? So probability swings towards that as you should chase that as your first port of call.
Offline Blakescarth
Re: HELPPP
« Reply #5 on: May 16, 2016, 01:57:51 am »
Cheers I'll get it plugged in tomoz and update you all
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: HELPPP
« Reply #6 on: May 16, 2016, 07:38:16 am »
I assume we are talking GTI? If so, DO NOT take any advice from whoever told you to clean the turbo vanes  :fighting: :fighting: :fighting: :signLOL:
Don't just 'plug it in' for a generic fault code scan.... Get it on a proper tool like VCDS and start looking at the live data. You can see exactly what the throttle body is doing just by looking at this data. A fault code scan alone is useless half of the time
Offline Gtiene
Re: HELPPP
« Reply #7 on: May 17, 2016, 10:34:24 pm »
Throttle body wires! I had my throttle body replaced by VW under warranty recently same issue booked it back in and advised me it's the throttle body wires this time, my warranty doesn't cover wires apparently so there going to replace as a gesture of good will because I have a service pack with them which is great! But check those wires first as they tend to fall short especially if your on stage 1
Offline Blakescarth
Re: HELPPP
« Reply #8 on: May 18, 2016, 08:54:05 am »
Took to my local garage it come up with mass airflow flap failed or something like that was cleared fixed and now running smooth ( for now )
Offline Paradox1
  • -Given: 41
Re: HELPPP
« Reply #9 on: May 18, 2016, 11:08:06 am »
That's not a solution though mate. its only a matter of time before it comes back.
As for the maf sensor..... Id imagine  it would be a loss of signal from the intake to the intake manifold. was the throttle body cleaned before installed? Check wires as they ca get hot and brittle.
Offline Blakescarth
Re: HELPPP
« Reply #10 on: May 18, 2016, 05:19:27 pm »
Your right light came back on already I'll take it back in to my mates garage this time as hes back the throttle body doesn't seem to be the problem I'll put the proper code up when I've got it :)
