Author Topic: Blowers/ heaters  (Read 3331 times)
Offline 8r0cky-gti
Blowers/ heaters
« on: May 16, 2016, 08:09:24 am »
Hi I'm new to golf's, I've done a bit of searching on the forum, but a quick question before I attempt to remove anything . When I got to turn on blowers/climate control everything lights up as it should and all numbers for climate control and the speed settings come on but no air is coming out. Any ideas would be helpful thanks dan
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Blowers/ heaters
« Reply #1 on: May 16, 2016, 02:27:58 pm »
Hello mate, check that the top dash vent is closed ie the one under the screen and then report back.
Offline 8r0cky-gti
« Reply #2 on: May 16, 2016, 05:34:33 pm »
Hi r5gtt I checked top vent and yeah its  off
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 16, 2016, 09:31:18 pm »
Is the blower motor making any kind of sound?.
If not it maybe the module in the blower that has failed, can't remember what it's called  :stupid: loss of memory lol.
Oh yeah heater resistor  :grin:
Offline 8r0cky-gti
« Reply #4 on: May 16, 2016, 09:51:23 pm »
No noise what so ever mate so could be resistor??
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 17, 2016, 12:39:44 am »
Check fuses first then go for the resistor  :happy2:
Offline 8r0cky-gti
« Reply #6 on: May 17, 2016, 08:01:12 am »
All fuses are fine so il check resistor il try n find a guide to see how to find it
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: May 17, 2016, 01:23:41 pm »
Offline 8r0cky-gti
« Reply #8 on: May 17, 2016, 08:50:49 pm »
Bought a resister and having trouble locating it behind glove box, I did remove motor and gave a clean and it's all working again atm will still change resister once no I got correct location
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: May 17, 2016, 09:32:43 pm »
If it's not in this location try behind the near side console panel. You need to be looking for about four olthibk colour wires.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: May 17, 2016, 10:00:38 pm »
Apparently some of out gti's don't come with this resistor.
Found this on another thread courtesy of maxitrol.
Not all models had it though, depending on the system installed. Eg. Climatronic, climatic etc
Mine has Climatronic (digital dual zone climate control) and doesn't have a resistor.
The resistor is a match box sized thing, located behind the glove box, with a green coating. It has a white plastic loom connector.
Offline 8r0cky-gti
« Reply #11 on: May 18, 2016, 08:10:23 am »
I've got dual zone climate control I've looked at few videos and I've looked on my 2005 gti and I can't locate it does it Deff have one??
Offline 8r0cky-gti
« Reply #12 on: May 18, 2016, 08:12:01 am »
