Author Topic: Dsg fault  (Read 1991 times)
Offline j8mes_b
Dsg fault
« on: May 16, 2016, 01:07:24 pm »
Just had the dsg serviced. It was hesitating at pull off. Vw said they want another 176 quid to do the basic settings. Is this a software thing. They said it could need new mechatronics. Which sounds expensive. It pulls through the gears fine. Just initial pull off?
Sent from my HTC One_M8 using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Dsg fault
« Reply #1 on: May 16, 2016, 01:36:53 pm »
If it was the dealer who did the oil and fitler change then I'm guessing they've not done the adaption properly as I had this with a focus when I did the adaption and for some what reason it failed and when I took it for a test run it initially judders and ran okay so I did the adaption again and all was well  :phew: would have got my  :booty: kicked by manager for that as it was warranty.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Dsg fault
« Reply #2 on: May 16, 2016, 02:04:46 pm »
anyone with vcds can do this for you for a small fee.
Offline j8mes_b
Re: Dsg fault
« Reply #3 on: May 16, 2016, 02:21:17 pm »
I worked for a vw body shop in Birmingham. Popping back there Saturday morning for a chat lol
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Dsg fault
« Reply #4 on: May 16, 2016, 02:24:44 pm »
You should have gone back to vw and made it known that they didn't do the dsg reset after replacing the filter and oil.  :stupid: technician must have fooked up.
Offline j8mes_b
Re: Dsg fault
« Reply #5 on: May 16, 2016, 02:32:17 pm »
Oh it was VW Kettering who did it. First time I've ever used a stealer. And probably the last
Offline j8mes_b
Re: Dsg fault
« Reply #6 on: May 16, 2016, 02:39:45 pm »
It's still at vw. Picking it up this afternoon
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Dsg fault
« Reply #7 on: May 16, 2016, 04:54:40 pm »
I would speak to the sevice manager and put your thoughts through regards the dsg not being calibrated which is the reason it is jerky  :slap:
« Last Edit: May 16, 2016, 09:28:45 pm by r5gtt »
Offline j8mes_b
Re: Dsg fault
« Reply #8 on: May 16, 2016, 07:48:06 pm »
I did try but he had just gone home. One of the technicians said it's a software issue and that isn't related. I'm going to email vw tomorrow and ask why they don't do it as part of the service
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Dsg fault
« Reply #9 on: May 16, 2016, 09:29:35 pm »
If you didn't have the problem before taking it in for the service then I believe they fooked it up on calibration and denying it now.
Offline Lewo
Re: Dsg fault
« Reply #10 on: May 31, 2016, 08:04:25 pm »
How did it go OP?
