Author Topic: eBay headlights  (Read 3561 times)
Offline bad devotions
  • -Given: 19
eBay headlights
« on: May 23, 2016, 09:04:32 am »
Hello everyone,
been a while since my last post....
anyway, has anyone installed these (or something like these)?
http://www.ebay.co.uk/itm/361401445960?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i am considering getting some.. My passenger headlight has gone all glazed and crackled and quite like the look of these.
thanks
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: eBay headlights
« Reply #1 on: May 23, 2016, 09:24:15 am »
They are horrible imo. Angel eyes only belong on bmw.
The depo projectors are much better and same sort of price.
  • -Given: 19
Re: eBay headlights
« Reply #2 on: May 23, 2016, 09:41:49 am »
thanks for your opinion slix.
are these the type of thing you mention?
http://www.ebay.co.uk/itm/VW-Golf-MK5-2003-2009-R32-Gti-Style-Black-Projector-Head-Lights-Lamps-Depo-Pair-/301204859556
would they be plug and play over standard lights or do i need more stuff to make them work?
Offline An0NyMOUs
  • A Nuisance
Re: eBay headlights
« Reply #3 on: May 23, 2016, 09:47:52 am »
I'd go for the second set you posted. I have these. Direct fit to mk5 golfs, no modifications needed.
2.0 FSI 4motion
  • -Given: 19
Re: eBay headlights
« Reply #4 on: May 23, 2016, 09:54:14 am »
cheers guys. i just read another thread on here and the only thing that's required from a coding point of view is to mark the "xenon" checkbox in VAG_COM.
it's my birthday tomorrow so i'll take the plunge and order a set. :D
  • -Given: 19
Re: eBay headlights
« Reply #5 on: May 23, 2016, 09:57:35 am »
done! just need the bulbs now :D
Offline slix
  • -Receive: 38
Re: eBay headlights
« Reply #6 on: May 23, 2016, 11:22:29 am »
Shouldn't have to do that as they are just using your normal bulbs.
  • -Given: 19
Re: eBay headlights
« Reply #7 on: May 23, 2016, 11:26:26 am »
lol! ok mate. Just was slightly confused after reading this thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,94391.0.html
i'll just see what happens when they arrive and if i can use the bulbs i already have. Might have got confused about using halogen bulbs in those headlights and doing some mods on the bulbs themselves.
i'll find out on wednesday i guess :D
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: eBay headlights
« Reply #8 on: May 23, 2016, 11:29:17 am »
If you're going to be using xenon bulbs you will have to code them in on vagcom without shutters or you'll blow your wiper motor. Raz told me this amd others have blown their wiper motors by not doing so.
Happy birthday  :signLOL:
Offline slix
  • -Receive: 38
Re: eBay headlights
« Reply #9 on: May 23, 2016, 11:39:09 am »
With the xenon bulbs you need the balasts and igniters right? And don't you have to mod the hole for them to fit in the bulb holders too?
I was going to get some depo lights and just use my normal halogen bulbs but was worried the light output would be even worse than stock and would look pants.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: eBay headlights
« Reply #10 on: May 23, 2016, 11:53:05 am »
putting halogen bulbs in them will low light output.
Get one of these
http://www.hids-direct.co.uk/ultra-35w-slim-hid-xenon-conversion-kit-h1-h3-h4-h7-h8-h9-h11-9005-9006/
Thats what I got in mine with 5000k bulbs. You can screw the ballast under the headlight and you will need to drill a hole in the plastic cap for the wires to go through. Really easy to do. And yes you should get someone with VCDS to tick the box that says Xenons without shutters installed to avoid wiper motor from failing.
  • -Given: 19
Re: eBay headlights
« Reply #11 on: May 23, 2016, 12:01:30 pm »
nice one guys thanks for the info.
so basically, i can use the depo lights with my existing halogen bulbs, but the light output will be lower than standard.
next step, once installed is to get the kit that retroraz mentioned which includes xenons and other stuff and then re-code via vcds.
sounds like a plan?
edit: and thanks r5gtt :)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: eBay headlights
« Reply #12 on: May 23, 2016, 12:09:28 pm »
I'd advise you to install the xenon hid kit before headlights go in as it'll be a lot easier or its double the trouble.
  • -Given: 19
Re: eBay headlights
« Reply #13 on: May 23, 2016, 12:21:56 pm »
lol! nothing's ever simple :D
right - i'll order that kit then for H7 bulbs i think it is
Offline An0NyMOUs
  • A Nuisance
Re: eBay headlights
« Reply #14 on: May 23, 2016, 12:23:48 pm »
I'd personally advise a 55w kit too.
2.0 FSI 4motion
