Author Topic: What's this called? Gearbox related  (Read 2033 times)
Offline Chris92
  • -Given: 33
« on: May 23, 2016, 10:17:04 pm »
Hi people have t had no luck as of yet on the mk4 forum so hoping someone on here will know.
whats this little gold colour ring called or if you can even buy it separate? It's sits on the drive shaft flanges that connects the shafts to the gearbox. Pics will show you what I'm on about.
Here's the flange with the part on
Here's the part in question
The one in the pic is the good one it's the other side one it has broken into two parts.
Removed one from a tdi hoping it would be the same but sadly the diesel one is a bigger diameter.
Any help would be great as I'm pretty much stuck without it.
« Last Edit: May 23, 2016, 10:20:52 pm by Chris92 »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: What's this called? Gearbox related
« Reply #1 on: May 24, 2016, 01:07:12 am »
Its cheaper to buy a used inner shaft knuckle but @tappy may know.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=m0dsmub9bm6dofk5kpggc6jefu&/topic,19740.0.html
« Reply #2 on: May 24, 2016, 01:10:30 am »
Just commented on mk4s... "Brass Differential Ring"
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 24, 2016, 01:13:07 am »
Give these guys a call if you're stuck.
http://m.ebay.co.uk/itm/150977609804
« Last Edit: May 24, 2016, 01:28:59 am by r5gtt »
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #4 on: May 24, 2016, 10:35:20 pm »
Just seen this sorry. Looks like you have found it on ebay now  :signLOL:
You lot need to go to sleep earlier  lol
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 24, 2016, 10:58:38 pm »
lmao @tappy some of us sados meaning me doesn't have a job again  :sad1: till next 1st June  :jumping:
Offline TAPPY
  • -Receive: 56
« Reply #6 on: May 24, 2016, 11:00:49 pm »
I must admit when I'm not at work I stay up that late  :signLOL:
Hope the next job turns out better than this one  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: May 24, 2016, 11:03:58 pm »
I seriously hope so seriously.
Thanks Tappy means alot mate.
