Author Topic: Funny 'Computerish' Noise Coming From Right Side Wheel Arch  (Read 1235 times)
Offline JamieBiz
  • Hiss, Pop, Gone...
As above really, i keep hearing a noise coming from the wheel arch area (Cannot put my finger on the exact location) and it almost sounds like a computer grinding away in there???
The other night my partner came home from work about 6 hours after i had last driven the car and it was making the funny nose, its only making the noise every now and again.
Has anyone ever has this noise or know what it might be?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Funny 'Computerish' Noise Coming From Right Side Wheel Arch
« Reply #1 on: May 24, 2016, 02:08:22 pm »
Hi I'm guessing your alarm siren is either not working or about to fail on you. It's mounted under the arch liner in an alloy box that's riveted to the body so if it is the cause you'll need to drill the rivets out to gain access.
Replacements are cheap enough.
Hope this helps.
R5
Offline JamieBiz
« Reply #2 on: May 24, 2016, 03:27:33 pm »
Ah ok thanks mate! as it happens i noticed for the first time this weekend that my alarm was going off when i left a window open in the sun but the siren wasn't going off
Ill take a look at that
Cheers r5gtt
Offline raz469
« Reply #3 on: May 24, 2016, 03:56:43 pm »
While your at it check your water channels. I found this the other day, knew it was bad but wow.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: May 24, 2016, 05:40:10 pm »
Cheers r5gtt
Not a problem what so ever.now you've mentioned the above and no sound with alarm going off. It's definitely the siren.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #5 on: May 24, 2016, 05:42:16 pm »
Nice! That's one lovely little job I should have got round to by now. But I'm getting new wings in a few weeks, so hey ho.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 24, 2016, 08:01:20 pm »
Nice axle stand  :signLOL:
