Author Topic: 345mm Front brake upgrade questions  (Read 10408 times)
Offline fazi123
Re: 345mm Front brake upgrade questions
« Reply #15 on: June 06, 2016, 01:15:17 pm »
Why not fit braided lines instead? From HEL, Goodridge or custom made, for example.
I don't know which to buy? In terms of cost they are probably very similarly priced ~£30/40 for the pair. I've just seen a few threads on here where people have ha to make modifications to the connectors etc, and its not something I feel comfortable with on something like the brakes.
If you know of direct fit braided brake lines, I'd love to know which ones are a good fit :)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #16 on: June 06, 2016, 01:19:59 pm »
My mechanic had to modify the connectors of the HEL braided lines I got and I saw him replying in a different forum that all brands need some connector modifying to make them fit like the OEM ones. If you want plug&play lines I guess you'd have to buy custom made to your preference. The mod required seems simple but only for mechanics, I guess.
Offline bigmig95
  • -Receive: 50
« Reply #17 on: June 06, 2016, 01:26:10 pm »
Anybody able to help me out with OEM part numbers for the brake lines to make the S3 brakes fit?
Are they the ones marked as Flexi Hose in the post by @bigmig95 above?
Thanks,
Faz
They sure are  :happy2:
Offline fazi123
« Reply #18 on: June 06, 2016, 01:29:13 pm »
Thanks,
Faz
Thank you :)
Are they the same for both sides?
Offline fazi123
« Reply #19 on: June 06, 2016, 01:30:24 pm »
That's the thing I had seen. I'm trying to do it myself and as I have no plans on tracking the car I don't think I will have any noticeable benefit in going for braided lines.
Offline bigmig95
  • -Receive: 50
« Reply #20 on: June 06, 2016, 01:49:42 pm »
Thanks,
Faz
Thank you :)
Yup.  You can use HEL but make sure they have the angled banjo onto the caliper for correct fitment.  Should be a photo on the forum somewhere, I've sold them before.
An OEM purchase off TPS might be easier for peace of mind ?
« Last Edit: June 06, 2016, 01:51:29 pm by bigmig95 »
Offline fazi123
« Reply #21 on: June 06, 2016, 02:05:31 pm »
Thanks,
Faz
Thank you :)
Can i use HEL lines without any modifications IF they have the angled banjo for fitment onto the caliper? Or would I still have to do some modification to make them work?
Thanks again!,
Faz
Offline Paradox1
  • -Given: 41
« Reply #22 on: June 06, 2016, 02:44:22 pm »
I was under the impression the only modifying you have to do is adjust where the braided lines click onto the securing bracket?
Offline bigmig95
  • -Receive: 50
« Reply #23 on: June 06, 2016, 02:47:49 pm »
Thanks,
Faz
Thank you :)
Thanks again!,
Faz
Buy the R32 HEL lines and you won't have to do any modding AFAIK
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #24 on: June 06, 2016, 03:21:46 pm »
I bought R32 HEL lines for my GT Sport and my mechanic had to get a different bolt for the lines. I complained but the store told me that they sold a lot with no issues. It was easily fixed and since then I had no issues with the lines.
Offline grey golfster
  • -Given: 79
« Reply #25 on: June 06, 2016, 03:27:09 pm »
[/quote]
[/quote]
Imho you'd be mad not to go for upgrade to braided lines, particularly if it seems you'll need new hoses anyway?
You can feel the positive difference at the pedal, with the braids.
Offline v4rley
  • -Receive: 104
« Reply #26 on: June 06, 2016, 04:00:09 pm »
Speak with @vRSAlex (aks tuning) he will ensure you get the correct fitment and more than likely on his shelf  :wink:
