Author Topic: Could Twintake owners please check and report back...  (Read 8845 times)
« on: January 15, 2010, 08:00:28 pm »
Been looking at a k03 GTi yesterday that had one of these fitted.
On checking the fitment I noticed that the top cannister was touching a hard bit of plastic that was attached to the intake manifold via a rubber tube (vacuum related me thinks).
Could you twintake owners of either k03 or k04 cars please check to see that you have clearance between these two items as I think this could be just a fitment issue.
And in case your lost as to where to look, I've circled the area on one of RR's review pics
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Could Twintake owners please check and report back...
« Reply #1 on: January 15, 2010, 08:18:35 pm »
It's a tight spot in there, the EVOMS sits close to it as well.
Stu...
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: January 15, 2010, 08:21:47 pm »
is it breakable, if so .....engine mounts should stop that movement :party:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: January 15, 2010, 08:24:46 pm »
Sure it's breakable, it's small and plastic.
I think it's a non return for the vacuum and it connects directly to the inlet manifold.
Stu...
« Reply #4 on: January 15, 2010, 08:30:38 pm »
the evoms has a cut out in the air panel so it sits perfect  :smiley:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: January 15, 2010, 08:32:19 pm »
That must be a later revision then Matt, none of the ones I've had were like that.
Stu...
« Reply #6 on: January 15, 2010, 08:34:34 pm »
u can see the hole at the top half way along
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: January 15, 2010, 09:33:08 pm »
No holes in this one -  :wink:
Stu...
« Reply #8 on: January 15, 2010, 09:38:27 pm »
so it looks like evoms made a change to them then so its for forge to sort the twintake out asap as they must have seen it rubbing the can
« Reply #9 on: January 15, 2010, 09:45:49 pm »
They must have changed the EVOM's heatshield as I cut a hole in mine to get the valve to fit
I then covered the hole with heat protective film to stop heat from the engine being pulled into the intake area :happy2:
PS..... I also have engine mounts, so the engine won't move anywhere now :smiley:
« Last Edit: January 15, 2010, 09:47:59 pm by Hurdy »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: January 15, 2010, 09:47:06 pm »
Matt, did you buy yours new or used, or from JKM?
Stu...
« Reply #11 on: January 15, 2010, 09:48:27 pm »
bought mine off hedge mate so he might have done it maybe  :laugh:
« Reply #12 on: January 15, 2010, 09:51:53 pm »
I am sure our favourite Doctor is still waiting patiently for a answer, I am not to sure he wanted to know about the Evoms.  :laugh:
« Reply #13 on: January 15, 2010, 09:53:12 pm »
well he should have bought the evoms then  :P
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #14 on: January 15, 2010, 09:54:48 pm »
Yes that explains it  :wink:
Stu...
