Author Topic: Bled brakes and clutch now clutch pedal has no pressure n hits floor  (Read 3566 times)
Offline Johnsy
Doesn't seem to be any fluid coming out of the clutch bleed nipple but the resivour is full
HELP
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Bleed the clutch simple  :signLOL:
Offline Johnsy
Thats the problem, doesn't seem to pulling fluid through
Offline r5gtt
  • -Given: 342
  • -Receive: 334
What through the bleed nipple on the gear box?.
Keep pumping it will come out.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=8pk530jva1gjq3nmtoe08nsvht&/topic,19740.0.html
My guess is you are not bleeding the clutch correctly.
Offline Johnsy
Doing the whole job again, can only think the resivour has got low and pulled air through
Offline r5gtt
  • -Given: 342
  • -Receive: 334
I agree
Offline Johnsy
Educate me please!
Resivour cap off , vacuum on bleed nipple , turn on suction ,crack open nipple keeping res full , close nipple before removng vacuum
I thought you were supposed to do it by pumping the clutch pedal?
Offline Johnsy
I think the problem is I assumed the fluid level should be where the seam is on the resivour, I couldn't see a level indicator so iv let the fluid drop to near the bottom of the yellow strainer, keeping the fluid level at the top it so I think letting it drop has passed the clutch pick up , I could be wrong but hey ho, sorted now
Offline r5gtt
  • -Given: 342
  • -Receive: 334
You can do it without pumping the pedal as ive done but it wasn't on a golf.
I ran the reservoir low when it had the tt not realising where the top was like you but in all honestly it need to be topped to the top so you don't run low.
Offline Johnsy
all sorted now,there was a bit of head scratching as there isn't an indicated level that I could see.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
I know VW Audi group are fools for this :stupid: design.
Glad it's sorted.  :happy2:
