Author Topic: Reflex Silver Mk5 Golf GTI  (Read 25058 times)
Offline JamieKirk95
Re: Reflex Silver Mk5 Golf GTI
« Reply #60 on: May 09, 2017, 05:14:35 pm »
No major updates on the Golf recently. However, last month I passed my LGV license so I can now drive the Fire Engine:driver:
Anyway, I've done a couple of little cleaning jobs on the Golf while I had a bit of spare time.
So I made a start in the boot by removing the carpet, tool set and spare tyre.
IMG_5870 by jamie kirk, on Flickr
IMG_5871 by jamie kirk, on Flickr
Hoovered out the rubbish
IMG_5872 by jamie kirk, on Flickr
IMG_5873 by jamie kirk, on Flickr
IMG_5874 by jamie kirk, on Flickr
Obliterate used
IMG_5875 by jamie kirk, on Flickr
IMG_5876 by jamie kirk, on Flickr
And finished
IMG_5877 by jamie kirk, on Flickr
IMG_5878 by jamie kirk, on Flickr
The next thing I decided to clean was in and around the fuel cap
IMG_5891 by jamie kirk, on Flickr
IMG_5892 by jamie kirk, on Flickr
Grime out
IMG_5893 by jamie kirk, on Flickr
After the first pass
IMG_5894 by jamie kirk, on Flickr
And after
IMG_5895 by jamie kirk, on Flickr
IMG_5896 by jamie kirk, on Flickr
And finally I got the car MOT'd towards the end of April - Advisory free:)
IMG_5923 by jamie kirk, on Flickr
Jamie
« Last Edit: August 02, 2017, 12:20:43 am by JamieKirk95 »
Offline stomper
« Reply #61 on: May 09, 2017, 06:04:43 pm »
Haha glad to see i am not the only one who cleans inside the fuel filler area  :grin:
Offline JamieKirk95
« Reply #62 on: August 02, 2017, 12:21:39 am »
Another small update again,
I had planned to do a full cleanup before I go to Cornwall at the end of the month, I decided to make a start by cleaning and polishing the sills.
Before
IMG_5966 by jamie kirk, on Flickr
IMG_5967 by jamie kirk, on Flickr
IMG_5968 by jamie kirk, on Flickr
IMG_5969 by jamie kirk, on Flickr
GrimeOut used and agitated with a detail brush
IMG_5970 by jamie kirk, on Flickr
IMG_5971 by jamie kirk, on Flickr
Wiped down
IMG_5972 by jamie kirk, on Flickr
Polished using Auto Finesse Tripple
IMG_5973 by jamie kirk, on Flickr
IMG_5974 by jamie kirk, on Flickr
IMG_5975 by jamie kirk, on Flickr
IMG_5977 by jamie kirk, on Flickr
IMG_5978 by jamie kirk, on Flickr
Drivers side
IMG_5979 by jamie kirk, on Flickr
IMG_5980 by jamie kirk, on Flickr
IMG_5981 by jamie kirk, on Flickr
IMG_5982 by jamie kirk, on Flickr
IMG_5983 by jamie kirk, on Flickr
IMG_5984 by jamie kirk, on Flickr
I also noticed the door locks could do with a polish
IMG_5985 by jamie kirk, on Flickr
IMG_5986 by jamie kirk, on Flickr
After
IMG_5987 by jamie kirk, on Flickr
IMG_5988 by jamie kirk, on Flickr
IMG_5989 by jamie kirk, on Flickr
Passenger side
IMG_5990 by jamie kirk, on Flickr
IMG_5992 by jamie kirk, on Flickr
I ordered a friends service parts through tps and got him good discount, so as he was going to pick the bits up I ordered a couple of things and got him to pick them up for me.
IMG_5996 by jamie kirk, on Flickr
I then diluted the screen wash to the correct dilution using de-ionised water, I have worked out the following;
1 Litre VW screen wash - £4
5 Litre De ionised water - £2
I diluted it down to 1:4 as recommended, the washer tank is 4 litres so works out that it costs just under £5 a time.
IMG_5997 by jamie kirk, on Flickr
IMG_6001 by jamie kirk, on Flickr
First I used the wipers to get rid of all existing screen wash, I then flushed the remainder out with normal water through the washer jets.
IMG_5998 by jamie kirk, on Flickr
Finally another small detail that was missing
IMG_6002 by jamie kirk, on Flickr
IMG_6003 by jamie kirk, on Flickr
IMG_6004 by jamie kirk, on Flickr
IMG_6005 by jamie kirk, on Flickr
Jamie
Offline JamieKirk95
« Reply #63 on: August 02, 2017, 12:22:45 am »
All photos now changed to flickr so now showing:) Will put some more updates tomorrow.
Offline JamieKirk95
« Reply #64 on: August 02, 2017, 04:32:25 pm »
So recently I haven't been using the golf as much due to buying a second car:D
Here she is
IMG_6083 by jamie kirk, on Flickr
I bought the corsa off a good friend who had had it since new, his in laws had just given him their old car so he was selling this. I bought it for £200 with just over a month left on the mot. Im not one to turn down a project so I did a bit of work on the car, I cleaned it up, serviced it and changed the exhaust and handbrake on it so it passed the mot. This monday I sold the corsa for £650 and during the month I had it I put about 1000 miles on it, so kept them miles off the golf:thumb:
This then gave me the chance to get the golf up on axel stands so I could take the arch liners off give them a good clean and then paint the disc hubs and repaint the red calipers as they had started to fade.
Heres just one pic to show them, the weather hasn't been good enough recently to get some good pics
IMG_6145 by jamie kirk, on Flickr
I had the golf on the axel stands for about 9 days, it wasn't until the day I took the golf off them that I realised I should have disconnected the battery.
The car wouldn't start so I had to jump start it from the corsa, I then took it for a drive and called in at shell to put some vpower in it. All good until I go to start it again and it wouldn't so I had to get someone to jump start it again and got it back home.
I was going to replace the battery before winter anyway so I knew which one I wanted anyway so ordered a Varta.
Heres the old one
IMG_6118 by jamie kirk, on Flickr
Battery out and air filter off
IMG_6119 by jamie kirk, on Flickr
Cleaned out
IMG_6120 by jamie kirk, on Flickr
I also cleaned the area where the filter sits as you can't get to it normally
IMG_6121 by jamie kirk, on Flickr
New battery in
IMG_6122 by jamie kirk, on Flickr
IMG_6123 by jamie kirk, on Flickr
Oil Filler Neck
As my car has the evoms intake kit on it the standard engine cover no longer fits without modifying it however I like the way it looks without. The oil filler has a neck on it so it sits flush with the cover, this neck is just held on by glue so I decided to get rid of it so my cap would then sit flush on the cam cover.
IMG_6125 by jamie kirk, on Flickr
IMG_6126 by jamie kirk, on Flickr
Cloth in to stop any plastic falling in
IMG_6128 by jamie kirk, on Flickr
Removed
IMG_6130 by jamie kirk, on Flickr
IMG_6129 by jamie kirk, on Flickr
After
IMG_6131 by jamie kirk, on Flickr
IMG_6132 by jamie kirk, on Flickr
I ordered an r8 oil cap from tps as I think they look nicer and just add a little touch to the engine bay
IMG_6133 by jamie kirk, on Flickr
IMG_6134 by jamie kirk, on Flickr
The next thing I set about changing was the washer cap and coolant cap as they was blue and didn't match anything in the bay so ordered the black set from AKS Tuning
Before
IMG_6127 by jamie kirk, on Flickr
IMG_6135 by jamie kirk, on Flickr
IMG_6137 by jamie kirk, on Flickr
And after
IMG_6136 by jamie kirk, on Flickr
IMG_6138 by jamie kirk, on Flickr
All three
IMG_6139 by jamie kirk, on Flickr
The next upgrade I bought was the gfb dv which i'm hopefully fitting with a friend next week
IMG_6148 by jamie kirk, on Flickr
IMG_6149 by jamie kirk, on Flickr
I'm looking at getting the car remapped and will be upgrading the oil to millers nanodrive 5w40 so ordered a new oil filter and sump plug while at tps
IMG_6150 by jamie kirk, on Flickr
Finally
I am getting the cam chain and tensioner replaced in a couple of weeks so got the parts from tps
IMG_6151 by jamie kirk, on Flickr
IMG_6152 by jamie kirk, on Flickr
Jamie
Offline JamieKirk95
« Reply #65 on: August 16, 2017, 03:24:43 pm »
So on monday I met up with @Tfsi_Mike who helped me fit my new gfb dv+
IMG_6167 by jamie kirk, on Flickr
IMG_6166 by jamie kirk, on Flickr
The old diaphragm was fine, no tears but just a nice upgrade to do, knowing this one is much more robust!
Yesterday I had my timing chain and tensioner replaced, the old one was starting to rattle a bit, noticeable on idle when it was up to temperature.
Cams locked in place with correct vw locking tool
IMG_6179 by jamie kirk, on Flickr
Old Chain and tensioner
IMG_6180 by jamie kirk, on Flickr
Chain removed
IMG_6181 by jamie kirk, on Flickr
New chain and tensioner fitted
IMG_6182 by jamie kirk, on Flickr
The car is now much quieter than before, it didn't necercassirly need doing yet however this is more for my peace of mind and its nice knowing its been done.
Whilst having the timing chain done it gave me chance to look at the underside of the car. It turns out I've not got a cat back exhaust. Ive got a full turbo back miltek exhaust with sports cat I couldn't believe it! The last owner was quite clued up it seems!! :smiley:
Jamie
« Last Edit: August 16, 2017, 03:37:50 pm by JamieKirk95 »
Offline JamieKirk95
« Reply #66 on: September 04, 2017, 10:12:49 pm »
So today I changed the oil, filter and sump plug.
IMG_6207 by jamie kirk, on Flickr
IMG_6228 by jamie kirk, on Flickr
IMG_6229 by jamie kirk, on Flickr
IMG_6230 by jamie kirk, on Flickr
IMG_6231 by jamie kirk, on Flickr
Whilst under the car I discovered a couple of power flex bushes :smiley:
IMG_6233 by jamie kirk, on Flickr
IMG_6234 by jamie kirk, on Flickr
Old oil and filter
IMG_6235 by jamie kirk, on Flickr
New filter in
IMG_6236 by jamie kirk, on Flickr
Jamie
Offline Mike58
« Reply #67 on: September 15, 2017, 08:02:15 pm »
Loving the detail in the write up. Looks like you have a nice clean car there. Glad you got the wings sorted, I'm just about to attempt mine and my wife's car too! Fingers crossed!
Out of interest what did you pay for the parts and labour for the tensioner and gaskets.
Just ordered the same switches as yours too thanks for the inspiration! :happy2:
Offline JamieKirk95
« Reply #68 on: September 16, 2017, 07:35:13 pm »
Thank you mate, fingers crossed then!
The parts came to £167 from TPS and £150 for the labour off a friend so just over £300 really :happy2:
Offline JamieKirk95
