So with the MOT coming up this month I decided to fix the only advisory the car got last year; the high level brake light.
Volkswagen would charge just under £400 to do this job as they say that you need to remove the rear spoiler to access the light. Having read up online I decided to do the fix myself. So on the day I had my cruise control fitted I nipped to TPS to get the new one.
IMG_5688 by
jamie kirk, on Flickr
The advisory last year was High level brake light not illuminating but not more than 50%
Before
IMG_5694 by
The light appears to have let water in over the years which i'm guessing why some of the led's have stopped working, a comparison;
IMG_5691 by
IMG_5692 by
The new one
IMG_5693 by
So we started by drilling a hole into the old one to break the cover
IMG_5697 by
We then used a screwdriver in the hole we made to use to push out the old light
IMG_5698 by
We then pulled the wire out to expose the connector
IMG_5699 by
IMG_5700 by
All connected and tested to make sure it worked
IMG_5702 by
And fitted
IMG_5703 by
IMG_5704 by
Finally I angled the rear screen washer jet to the right so will not be directly towards the light.
Jamie
