Author Topic: Heater not working vagcom scan inside  (Read 2989 times)
Offline Scoobykiller
« on: June 03, 2016, 11:46:33 am »
Posted about heater not working few days ago
Here is what it shows on vagcom
Any ideas
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Heater not working vagcom scan inside
« Reply #1 on: June 03, 2016, 12:01:18 pm »
Your G65 sensor has probably failed
Part number - 1K0-959-126-A
P00576 can be any number of things
http://wiki.ross-tech.com/wiki/index.php/00576
« Reply #2 on: June 03, 2016, 01:28:08 pm »
Where does the sensor go and would it cause the heater to not work
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: June 03, 2016, 01:44:23 pm »
Sensor sits in front and just slightly below auxiliary - See latest update http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
I don't think that would affect the heater though I'm afraid....
Offline DANBOY66
  • -Given: 41
« Reply #4 on: June 03, 2016, 01:47:42 pm »
i have a complete heater box if you need any parts  :happy2:
Dan..
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: June 03, 2016, 02:53:33 pm »
Dude how many different posts on this subject have you posted?. :signLOL:
Again take the blower out and check it. could even be the heater resistor.
G65 is the air con switch/sensor outside the car in front of the alternator.
« Reply #6 on: June 04, 2016, 09:40:46 pm »
My gti has clumate control so blower will be differenr??
« Reply #7 on: June 06, 2016, 06:53:50 pm »
Does the climate control gti share same resistor as normal blower non climate control?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: June 06, 2016, 06:57:26 pm »
Yes it does as I don't recall seeing a second blower and can hear mine blow faster and slower when con on and off.
« Last Edit: June 06, 2016, 06:58:57 pm by r5gtt »
