Author Topic: Refitting Pinch Clip - Gear Stick Replacement  (Read 2110 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: June 05, 2016, 03:31:53 pm »
I know a cable tie can be used but if I want to refit a new pinch clip, how do people secure them? Is it just a case of squeezing the crap out of them with a pliers?
Part number handy to anyone please
4ndy
Re: Refitting Pinch Clip - Gear Stick Replacement
« Reply #1 on: June 05, 2016, 03:59:36 pm »
If you mean the O ring ear clips   http://www.ebay.co.uk/itm/LARGE-8-NAIL-REMOVER-PULL-BALL-CLAW-PINCER-PLIERS-Carpenter-Pinch-Pin-Lever-/191131312728  Nip between the ears and the skull
EDIT  Not toooooo tight as the plastic your pinching onto is fragile
« Last Edit: June 05, 2016, 04:01:27 pm by 4ndy »
Offline bluebert92
« Reply #2 on: June 05, 2016, 05:13:00 pm »
small jubilee clips?
Offline Matto
  • -Receive: 116
« Reply #3 on: June 05, 2016, 06:21:35 pm »
They're called Oetiker Clamps  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: June 05, 2016, 09:34:00 pm »
The clips are called double ear clamps.
You can use side cutters otherwise known as wire cutters to some.
Offline Pesky jones
« Reply #5 on: June 06, 2016, 08:53:50 am »
I think luke already has the tool to close this clamp - the pliers used for closing the clamp on a cv joint gaitor?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: June 07, 2016, 08:27:56 am »
@Peskyjones you're right, I did use it for the CV and had a feeling it was the same tool but wanted to confirm....
Unfortunately I broke the cheap eBay one so I'll buy another one now in preparation!
