Author Topic: Problem with G85 / clock spring after MFSW retrofit  (Read 19211 times)
Offline supercati
« on: June 07, 2016, 08:36:53 pm »
EDIT: Problem was solved. You can read through the thread.
Hello there.
This past weekend I had Tempomat + MFSW installed on my Golf mk5 (2007 1.4 TSI 170).
Tempomat works great, Multifunction steering wheel too (horn, buttons, ilumination)... but, I cannot erase G85 errors. I believe this is also steering angle sensor / clock spring after some Google.
I've tried to do the basic setup, but it's impossible since the "Angle" value doesn't move from 0.00º (when I check in 03 - Brakes and Channel 004). Maybe it is broken? It was always working fine before removing steering wheel...
I tried this: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60) but didn't work either.
SMLS is ref. CH, clock spring ref. 1K0959653C.
Any help will be really apreciated!
« Last Edit: June 16, 2016, 09:04:12 pm by supercati »
Golf V GT Sport 1.4 TSI 170 '07
Offline supercati
Re: Problem with G85 / clock spring after MFSW retrofit
« Reply #1 on: June 08, 2016, 09:30:28 pm »
I replaced the G85 today for a brand new one... same result!! I cannot understand anything now.
What I am doing wrong? With VagCom still the same, cannot read any angle, I thought it was because of the G85 being defective but may be not?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: June 08, 2016, 09:44:49 pm »
Is this what you did?
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
Offline v4rley
  • -Receive: 104
« Reply #3 on: June 08, 2016, 09:45:22 pm »
Go into control module 44 steering assistance
[Select]
[44 - Steering Assist]
[Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
[Do it!]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 1 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 007
[Go!]
[Done, Go Back]
Offline supercati
« Reply #4 on: June 09, 2016, 12:17:06 pm »
R5gtt, I did that, but didn't work out. When I go to channel 60 the angle doesn't move from 0.00°, and if I try to do basic setting it says error.
[Select]
[Do it!]
Group 060
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Group 007
[Go!]
[Done, Go Back]
I haven't done this, so I'll give it a try later! And I'll post the result.
The only thing I don't understand at all:
[ON/OFF/Next]
What I am supposed to do after activating Basic Setting? The car will do it itself, or I need to drive, or turn left/right?
Thanks is advance :)
Offline v4rley
  • -Receive: 104
« Reply #5 on: June 09, 2016, 12:38:02 pm »
Above text is copied from here so follow on from there, so yes the next step would be setting the stop limiter
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Offline supercati
« Reply #6 on: June 09, 2016, 06:55:00 pm »
Still the same...  :doh: :stupid:
Steering Angle Sensor doesn't read any angle.
My ABS/ESP unit is MK60 so I need to follow this steps (#03, not #44): http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1J)_Brake_Electronics_(MK60)#Basic_Setting but I can¡t because I cannot activate Basic Settings.
When I go to Group 060 in Basic Settings, I get this:
If I try to read value of G85 in Channel 04, I get this, always 0.00º, no matter what:
Here's an autoscan I did, and all the Faults I found (maybe it helps):
Quote
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0002690
   Shop #: WSC 01279 785 00200
   VCID:
2 Faults Found:
00778 - Steering Angle Sensor (G85)
            014 - Defective
            005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 FH    HW: 5K0 907 044 FH
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID:
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 164610 km
                    Date: 2000.00.00
                    Time: 21:47:59
I have MK6 Golf Clima unit installed.
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   VCID:
2 Faults Found:
02546 - Steering Limit Stop
             Freeze Frame:
                    Mileage: 164600 km
                    Temperature: 45.0°C
                    Voltage: 12.30 V
                    Voltage: 12.10 V
            014 - Defective
             Freeze Frame:
Offline supercati
« Reply #7 on: June 09, 2016, 07:31:48 pm »
Also, I noticed my car doesn't have this under the "Steering Column"...
Not my car/photo
http://workshop-manuals.com/volkswagen/golf-mk5/images/golf-mk5-2424.png
Is it normal?
SWCM / SMLS before I had installed is 1K0 953 549 BC, now 1K0 953 549 CH (which is supposed to be compatible). The CH has like the space for this connector, which it doesn't exist in my car.
« Last Edit: June 09, 2016, 07:35:13 pm by supercati »
Offline v4rley
  • -Receive: 104
« Reply #8 on: June 09, 2016, 08:55:01 pm »
I sent that link as it recently resolved my g85 issues....
With regards to the above photo, your car does have it, it's behind the slip ring..
Offline supercati
« Reply #9 on: June 10, 2016, 08:17:01 am »
The photo is not from my car, I checked mine and I didn't have this thing behind the slip ring, why?
Isn't it the G85/slip ring the steering angle sensor itself?
Offline v4rley
  • -Receive: 104
« Reply #10 on: June 10, 2016, 12:05:15 pm »
Why not upload a photo of your steering colum...
Offline supercati
« Reply #11 on: June 10, 2016, 07:20:27 pm »
Here I am again with the updated requested @v4rley  :happy2:
With slip ring:
(notice this small metal piece there, I guess it is normal, right?)
After slip rinig removal... here's the weird thing: Where is my steering angle sensor???
Maybe with the other SWCM (ref BC) the steering wheel angle sensor what the slip ring itself? Honeslty couldn't find anything documented about this.
Should I buy a steering wheel angle sensor and install it? 1K0 959 654
« Last Edit: June 10, 2016, 07:29:47 pm by supercati »
Offline v4rley
  • -Receive: 104
« Reply #12 on: June 10, 2016, 08:28:23 pm »
Ah ok, looks like yours is built into your slip ring  :thinking:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #13 on: June 10, 2016, 10:08:40 pm »
I think they were built into the abs pump on later models.
Sent from my SM-G928F using Tapatalk
Offline supercati
« Reply #14 on: June 11, 2016, 10:04:35 am »
So, that's what I don't understand, it doesn't "work" now. Maybe because this new SWCM needs the steering angle sensor?
My Golf is 07/2007. For sure I didn't have it before... But seems not be working on my car the G85/steering angle sensor now.
Also, I have one of the "rear wheel bearings"  a little bit damaged/broken (it makes noise when driving +60kmh). There's there any ESP/ABS sensor? Could be any relation to that? Because before steering wheel swap I had no ABS /ESP Errors.
