November 18, 2024, 10:46:19 am
All Things Mk5
Mk5 General Area
Sound deadening
Topic: Sound deadening (Read 2150 times)
Madone
Always Involved
-Given: 8
-Receive: 27
Sound deadening
June 09, 2016, 10:23:20 am »
Hi All,
Has anyone fitted and sound deadening in the doors etc ?, I see the MKV allows you to remove the door skins from the door, has anyone done it this way or do you remove the door cars and go from the inside ?
theminty1
Always Involved
-Given: 2
-Receive: 8
Re: Sound deadening
Reply #1 on:
June 09, 2016, 10:32:41 am »
You need to remove the doors skins as there is no access by removing the door interior trim. if you do a search there have been several people have done it. Door handle and correct order for returning the screws are points to note.
140 BKD GT TDi 5dr
Madone
Always Involved
-Given: 8
-Receive: 27
Re: Sound deadening
Reply #2 on:
June 09, 2016, 10:52:45 am »
Ok, sounds interesting way to do it !
I guess most people do the doors and boot floor ?
theminty1
Always Involved
-Given: 2
-Receive: 8
Re: Sound deadening
Reply #3 on:
June 09, 2016, 11:36:22 am »
Different yes but it can give you a chance to check over the window winder wires etc.
Boot floor, doors and under rear bench seat.
http://forums.vwvortex.com/showthread.php?2984471-DIY-Passenger-Side-Door-Skin-Removal
http://www.golfmkv.com/forums/showthread.php?t=10694
etc
Last Edit: June 09, 2016, 11:40:03 am by theminty1
140 BKD GT TDi 5dr
Madone
Always Involved
-Given: 8
-Receive: 27
Re: Sound deadening
Reply #4 on:
June 09, 2016, 12:03:52 pm »
Cheers !
All Things Mk5
Mk5 General Area
Sound deadening
