Author Topic: Front Suspension bushes - recommendations  (Read 2516 times)
Offline bad devotions
  • -Given: 19
« on: June 12, 2016, 02:57:12 pm »
hey all,
My front lower (rearmost) bushes are up for replacing. I've read that S3 bushes are the way to go, but is there anything else i can do whilst i am there? Or would just the S3 bushes be a good call? any part numbers for the S3 bushes?
cheers
D
Offline Stupots
  • -Given: 18
Re: Front Suspension bushes - recommendations
« Reply #1 on: June 13, 2016, 12:20:15 pm »
Febi 33973 are solid OEM S3 bushes. I found them just right.
Discussed here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,107294.msg1040050.html#msg1040050
Stu
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: June 13, 2016, 01:50:51 pm »
Depends on the budget. I'd get a SuperPro anti-lift kit, which I fitted to both my Golfs. The ALK does make a worth while difference. You can consider the ALK from Powerflex, since it's cheaper.
  • -Given: 19
« Reply #3 on: June 13, 2016, 04:29:53 pm »
just so i am not throwing money away; what difference does it make?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: June 13, 2016, 04:43:28 pm »
You read about it in this topic: http://www.golfmkv.com/forums/showthread.php?t=181008.
It's a must do mod for me. :smiley:
  • -Given: 19
« Reply #5 on: June 13, 2016, 08:18:14 pm »
nice one. looks like the Whiteline Anti-lift kit is the way to go.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: June 13, 2016, 11:23:17 pm »
Not what I wrote before. Personally I prefer the SuperPro ALK but Powerflex sells one cheaper. An ALK is what you need. Whiteline doesn't have the quality or price advantage.
  • -Given: 19
« Reply #7 on: June 14, 2016, 10:47:05 am »
ok - thanks for that.... i did skim read so... Will investigate once my bank balance recovers a little. :)
Offline xjay1337
  • -Receive: 377
« Reply #8 on: June 14, 2016, 11:02:56 am »
I'd get the Superpro ones... speak to Alex at AKS Tuning.
