Author Topic: 02m or 02q  (Read 1801 times)
Offline Scoobykiller
02m or 02q
« on: June 14, 2016, 06:44:48 pm »
How do i know if my car has an 02m or 02q gearbox
Is is a 54 gti
Any visual way of knowing?
Offline OEM+ DUB
Re: 02m or 02q
« Reply #1 on: June 15, 2016, 09:09:52 am »
Hi there
If you have your original handbooks, the one with the data sticker on the inside cover should show the transmission code on the same line as the engine code.
On the car, the gearbox code is often stamped on the bottom of the bell housing - might need a wipe over to find it.
Hope this helps.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
