Author Topic: Stage 2 R-Tech Fuel cuts/limp mode?  (Read 5843 times)
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Stage 2 R-Tech Fuel cuts/limp mode?
« Reply #15 on: June 26, 2016, 09:46:05 pm »
Mine used to do the same thing, mapped to 330bhp by Rtech. Going WOT especially in higher gears the car would jolt pretty violently as it experienced fuel cuts and then would go into limp mode. Replaced HPFP with an autotech uprated one, new fuel filter etc but logged it and showed my LPFP was failing and couldn't keep up.
Interesting. Mine doesn't jolt, it's not at all aggressive. Just loses most of its power.
Was the low pressure pump a big job?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #16 on: June 26, 2016, 10:08:38 pm »
That's a bugger wash, did you replace the lpfp to cure the problem?.
