Author Topic: Retrofit Day Leicester/Nottingham, Saturday 1st July  (Read 11649 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« on: June 27, 2016, 04:14:49 pm »
Hi All,
Seeing if anyone is interested. Ill be up in Leicester and Nottingham to do a few retrofits.
I can do the following:
Multifunction steering wheel fitting
Cruise Control fitting (If the ECU cable already fitted)
Highline Cluster Upgrade ( i have 2 in stock! 1 TDI and 1 GTI) (04-06 years only)
Bluetooth kit Installation
All services will include coding and fault clearing.
Let me know so I can book you in. Already have 2 slots taken up.
Offline white91
Re: Retrofit Day Leicester/Nottingham, Saturday 1st July
« Reply #1 on: June 27, 2016, 06:30:15 pm »
Can you code and fit my highline clocks 972 into 2005 gti?
Offline white91
« Reply #2 on: June 27, 2016, 06:30:32 pm »
I'm Leicester
Offline Cadders96
« Reply #3 on: June 27, 2016, 06:40:19 pm »
Where you based usually?
VW Golf GTI Mk5 3 door
18" Monzas
Tinted Windows
Powervalve WRC Sports Cat-Back Exhaust with Decat Downpie 3" (Ebay Special)
Climair Wind Deflectors
HID Foglights
GFB DV+
Pre-Cat Delete
Offline shoaybmakda
  • -Receive: 54
« Reply #4 on: June 27, 2016, 06:40:28 pm »
@white91 he did mine - top service would recommend.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: June 27, 2016, 07:45:54 pm »
Yes buddy i can. Do you have the clusters? Or do you need me to supply them?
Sent from my SM-G928F using Tapatalk
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: June 27, 2016, 07:46:04 pm »
London.
Offline white91
« Reply #7 on: June 27, 2016, 07:48:00 pm »
Yeah I've got them, just need a multi function wheel now
Offline rashg60
  • -Receive: 41
« Reply #8 on: June 27, 2016, 09:25:36 pm »
Raz just seen this. What time will you be at mine for?
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
« Reply #9 on: June 27, 2016, 09:42:11 pm »
I'm 2mins from Jct25 (Nottingham) and would be so happy if you could
Suss out why I can't acces my MFD menus on my large display Cupra clocks!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: June 27, 2016, 10:00:51 pm »
Yeah sure i can do them. £40 fitting and coding
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: June 27, 2016, 10:01:17 pm »
Late afternoon bro, won't be able to stick around for long as im going to be at the in laws too.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: June 27, 2016, 10:02:02 pm »
Hey mike.
Ill check the part number, most likely you need a multi function steering wheel with menu button.
« Reply #13 on: June 27, 2016, 11:15:07 pm »
Funny you should say that. They worked by holding wiper rocker switch... Until i tried a Gti pirrelli wheel with menu button buttons. Not been able to access the menus since (I'm back on my Cupra wheel with auto control only buttons
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: June 27, 2016, 11:22:40 pm »
Same thing happenned to me.  I had a 972 cluster which worked off the stalk, i added it to a car which had a mfsw and then never worked off the stalk again!
I made a post about it but not had a lot of help. Seems like the 972 sort of self adapt to a steering wheel.
