Author Topic: Retrofit Day Leicester/Nottingham, Saturday 1st July  (Read 11508 times)
Offline TheBALDpuma
Re: Retrofit Day Leicester/Nottingham, Saturday 1st July
« Reply #60 on: July 23, 2016, 04:35:55 pm »
Hi mine is a 2008 58 plate car. The aerial is a black normal looking aerial at the back of the roof.
I'll keep an eye out when you're in they Midlands, but I do spend some time near London so could pop in when I'm down that way possibly? What area of London?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #61 on: July 23, 2016, 05:09:36 pm »
Hi chris
Yep 08 plate is easy for me to do. Next time im up in midlands will probably be in a few weeks. But definitely September 8th till 11th. I actually live in Walthamstow, London.
If you can buy the stalk, ill fit and code it for £30
Get a 1K0953513G.  The G versions are more solid than the A ones.
Sent from my SM-G928F using Tapatalk
Offline TheBALDpuma
« Reply #62 on: July 29, 2016, 09:32:17 pm »
Hi chris
Thanks, I'llbe in touch.  Unfortunately neither the midlands or north London are all that close, living in Leeds and parents in Guildford - but hopefully I'll be able to figure something out!
Offline TheBALDpuma
« Reply #63 on: August 01, 2016, 01:27:02 pm »
Do you fit NAV as well?  Is an aftermarket unit like this worth considering - the cheapest 2nd hand NAV+DAB I've found was £450 and it was a skoda one.
http://www.ebay.co.uk/itm/VW-Golf-Mk5-Mk6-Head-Unit-Stereo-DAB-Radio-Kudos-SatNav-GPS-Bluetooth-Scirocco-/172001713804?hash=item280c19de8c:g:0QgAAOSwOVpXenhc
How much would you charge for this? (Assuming you do it?)
Is  ~£30 for the indicator stalk about what I should expect from ebay, or are these cheap fakes?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #64 on: August 01, 2016, 01:37:26 pm »
Pmd
