Author Topic: RCD310 bluetooth mic not working  (Read 3932 times)
Offline Lyons
  • -Given: 18
« on: June 30, 2016, 09:26:14 am »
I removed an RNS510 from my car earlier in the week and have fitted an RCD310 in its place. I had a 7P6 bluetooth module workign with the 510 prior to removing it. However upon fitting the RCD310 the microphone no longer works.
Before I start into stripping the dash out again to check the microphone plug, does anyone know of any other reason why the mic wouldnt be working after the swap? I assume the pin locations on the RNS510 and RCD310 are in the same position ok?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: RCD310 bluetooth mic not working
« Reply #1 on: June 30, 2016, 10:21:58 am »
Could be the coding in the rcd310 or it could be the wiring as well. I remember ordering a bt loom from Eddie-NL and he asked me if it was for rns or rcd. So there may be some sort of difference.
Sent from my SM-G928F using Tapatalk
Offline Lyons
  • -Given: 18
« Reply #2 on: June 30, 2016, 10:25:47 am »
How would the coding differ to affect the mic?
Offline Pashka
« Reply #3 on: June 30, 2016, 10:37:24 am »
He had in mind voice control.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Lyons
  • -Given: 18
« Reply #4 on: June 30, 2016, 10:55:53 am »
So the only explanation would be a loose pin then?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: June 30, 2016, 10:59:17 am »
The coding in the RNS might be different to the coding in the RCD. Probably a checkbox for mic.
Offline Pashka
« Reply #6 on: June 30, 2016, 12:17:51 pm »
Your mic pins are going to bluetooth plug or green plug on the quad at the moment?
Offline Lyons
  • -Given: 18
« Reply #7 on: July 04, 2016, 08:27:25 am »
In this car they are going to the bluetooth plug, not direct to the quadlock.
But perhaps a pin mightve come loose either at the quadlock or the bluetooth plug?! Seems highly unlikely I know, but not sure what else could be causing it.
Offline Lyons
  • -Given: 18
« Reply #8 on: July 06, 2016, 03:31:49 pm »
I take that back actually. I just assumed the mic wiring pins were going to the bluetooth module, but they may not be!!
From what I can see online the mic is wired straight to the quadlock on an RNS with voice control, whereas they go to the bluetooth module in other cases. I haven't had a chance to strip the radio out again for a look, but assuming this is the case in my car, is it just a case of removing the 2 pins from the quadlock and fitting them in the bluetooth plug? Are the pins the same size?
Offline Lyons
  • -Given: 18
« Reply #9 on: July 06, 2016, 05:28:17 pm »
I see there are 4 mic pins at the quad lock, there's chat of joining 2 together?
