Author Topic: Misfire Issue - Resolved  (Read 2868 times)
Offline iian
« on: July 01, 2016, 09:34:54 pm »
Hi Folks,
Just firing up a thread on the issue I had in case it happens to anyone else. I dug around online, but couldn't find anyone with these exact symptoms. Many similar, none the exact same.
Basically the car was misfiring on full throttle between 3-5k revs. Started intermittently, then between 4-5k, then worsening to 3-5k revs. Full throttle only, and was fine above or below those revs. I had replaced 2 coilpacks before to solve misfiring, however those cases were full failure and the car constantly running off a cylinder, so I had kind of ruled out it being another coilpack issue.
A few runs of live testing on the road, all other potential sources looked fine. Getting fuel fine, getting air fine. We then went and borrowed 4 R8 coilpacks from a another MK6 GTI. Problem solved. The 2 coilpacks I'd got from VW to solve the earlier issues were different part numbers to the existing 2, so we thought they must have played around with resistances or some crap. So 4 R8 coilpacks later (and 6 in total  :sad1: ) and the car's driving perfect.
Hope this helps someone.
Thanks,
Ian
Offline th3_f15t
  • -Receive: 183
Re: Misfire Issue - Resolved
« Reply #1 on: July 02, 2016, 08:05:18 am »
Cheers for the write up, always good to have extra information in the bank. Did you replace the spark plugs at the same time?
Offline s3dubbin
« Reply #2 on: July 12, 2016, 12:27:33 pm »
I have a misfire on my s3 8p. My r8 coilpacks arrive today. They are 50k old so hoping all is sorted tonight.
Cheers, Stevie.
Offline gttdigoof
    • bf1systems
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,104209.0.html
« Reply #3 on: July 12, 2016, 02:37:30 pm »
If the coil packs dont work, use vcds, measuring blocks 15 & 16, that should tell you which cylinder its on
I swapped the plugs and coil packs and still had the misfire. Currently have my injectors being serviced at Mr Injector
 Mk6 R :)
