Author Topic: Mk6 climatronic problem  (Read 1202 times)
Offline K9
  • VW LifeStyle
« on: July 03, 2016, 07:54:43 pm »
Sup. Installed mk6 climatronic panel to my r32 2006. Had this panel fitted in my gti 2005 without any problems. Swaped the wires 16 and 20 and managed to do the first basic setting my adapting the flaps, then tried to do the compressor calibration but it seems to not work. Turning ac ON it will blow 1min air from all vents and then the air stops to blow but ac still ON by checking via VCDS meassuring blocks. How can i do the compressor calibration?
Skickat från min SM-G935F via Tapatalk
Offline Softishman
Re: Mk6 climatronic problem
« Reply #1 on: July 04, 2016, 08:08:41 pm »
You have to parrarrel connect your 2 vent flaps!! You can do this on the wiring to the mk6 climate control. Don't know now wich cables it is but i had the exact same problem!
Offline Softishman
« Reply #2 on: July 04, 2016, 08:10:16 pm »
This is it i think!! :thinking:
Offline K9
  • VW LifeStyle
« Reply #3 on: July 06, 2016, 03:50:38 pm »
hmm seems that i changed a vcds setting code it started to work  :thinking:
