Author Topic: bloody vw dealers  (Read 10172 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: bloody vw dealers
« Reply #30 on: January 30, 2009, 10:26:48 am »
Perhaps a better explantion of what I'm trying to say is here -
Quote
SPI-Wizard Master software features :
These features allow the Master to encrypt files based on rolling code technique or on credit basis. Files will be locked to the Slave device under this Master. Files encrypted with the rolling code technique will be valid for one flash only. After flashing the file a new code will be generated inside the device . Files encrypted based on credits can be used until the Slave device runs out of credits.
Additional features are enabled in this version including e-mail generator for requesting files from the Master, Return to standard code generator, credit generator and more.
http://chiptunawarehouse.com/ecutools/spiwizard-master-software-p-122.html
Stu...
Offline Shaun
« Reply #31 on: January 30, 2009, 05:09:45 pm »
Guys,
As I've just ordered a Bluefin handset can someone clarify the position on these dealer software upgrades for me for future reference? Once I've installed the new map, if the dealer installs an upgrade that 'overwrites' it can I not just reinstall the enhanced map from the handset when I get the car home, or will this not work if the 'basic' map is different from the original? Does it make any difference if I uninstall the enhanced map before taking the car into the dealer (I intend to do this anyway whenver the car goes in for work). Do I need to upload the new 'basic' map to Superchips each time this happens for them to provide a revised 'new'one?
Hope this makes sense!! As you can tell I'm a little confused by all this!
Thanks,
Shaun
Keep The Faith
GTI Edition 30 No. 0687 - Candy White - 5 Door - Lux Pack 1 - Park Sensors - ITG Filter - Bluefin - ECD Insert - Cruise Control
Previously: Mk1 Golf - Mk1 Jetta - Mk1 Polo Coupe - Mk2 Jetta - Mk3 Golf - Mk4 Passat - Mk1 Polo - Bora - Audi A4 / A6 / A8 - Mk3 Polo - Mk4 Golf
Offline 182_blue
  • -Receive: 54
« Reply #32 on: January 30, 2009, 05:26:21 pm »
if the dealers software upgrade wont let you reapply the map all you do is contact Superchips and they will allow the software to be reapplied to the car, and this should be free too  :happy2:
If you take it in for service etc, just take the map off the car using handset, then when you pick the car up (usually in the VW car park if your like me LOL) just use handset to put map back on, no need to upload map to superchips
« Last Edit: January 30, 2009, 05:55:36 pm by 182_blue »
Offline cmdrfire
    • Commander Fire - my blog
« Reply #33 on: January 31, 2009, 02:29:32 pm »
they said because the remap had to be reworked & wasn't the same as the orig thats why they charged me (but in the long run i got my money back)if i went down to their hq & the map was the same they would of put it on foc
@Shaun as well - my map had to be reworked after it had been overwritten by VW as well. The two files were not the same; I whipped the new VW file onto my Bluefin and sent it to Superchips, always within 24 hrs (one case within 2 hrs!) I got a revised "fast" map back, always free of charge. Now that is excellent customer service.
Shaun, do not try to reinstall the "fast" map back on - it will not work and the ECU will get upset. Best thing to do is to download the new VW map and send to Superchips where they can adjust it.
Offline Shaun
« Reply #34 on: January 31, 2009, 05:18:38 pm »
Great. Thanks for that additional information.
Just out of curiosity, though, why is this necessary? Surely Superchips don't re-work their upgrade maps every time VW distribute a software update?? Or do they?
When my handset arrives do I first have to upload my original map onto it and email it to Superchips? And if so do they then amend the upgrade software they send me to reflect my specific original map?
This is all fascinating!!
Thanks,
Shaun
Keep The Faith
Offline cmdrfire
« Reply #35 on: January 31, 2009, 05:35:47 pm »
Superchips modify their maps every time a VW update is released.
Each car has a slightly different map on it from factory. Superchips is the only company that allows you to retain your original map. When you get your Bluefin, plug it into the car; it will download the ECU file. Send this to superchips using the software provided, they will tweak this map to their latest standards and send it back to you (within 24 hours, but I've found that I often got 2-6 hour turnarounds). Your bluefin will retain both your customised map as well as your original map.
Offline Shaun
« Reply #36 on: January 31, 2009, 05:54:57 pm »
Thanks, cmdrfire. Very helpful.
This forum's brilliant!
Cheers,
Shaun
Keep The Faith
