Hi Folks,
I got my MK5 GTI scanned last night and I got this error code come up;
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0F4066292
Coding: 040300031C070160
Shop #: WSC 66565 257 00032
VCID: 2D556767B4477656E5-8078
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 115691 km
Time Indication: 0
Date: 2000.00.00
Time: 21:12:49
Freeze Frame:
RPM: 830 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 88.0∞C
Temperature: 28.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.208 V
Readiness: 0000 0000
Car is remapped and has K&N Typhoon Intake, GFB DV+ .
A quick search has come up with the following causes;
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
My question is, do any of you guru's know how to go about checking any of these?
Thanks in advanced!
