Author Topic: How do I adjust scirocco tailgate bump stops ?  (Read 2789 times)
Offline Steve in crete
« on: July 07, 2016, 08:36:43 pm »
Hi guys,
It must be a sign I am getting old or it's the sun got to me !
Everything's getting more complicated, bought a pair of sprung loaded bump stops to do the hatch pop mod, messing with them, as you do, I have managed to get them on their shortest height but for the life of me I can't work out how to adjust them out again !
As usual there is going to be an easy answer to this but as sure as hell I can't work it out ..
Thanks in advance
Steve
Offline Carpy25
Re: How do I adjust scirocco tailgate bump stops ?
« Reply #1 on: July 07, 2016, 09:19:47 pm »
There's a grub screw in the centre hole. 4 MM. I think unscrew that fully anti clockwise then use a flat blade screw driver to adjust the length by inserting it between even the base and the rubber and twisting it will pop out on a set of ratchet teeth then re tighten the grub screw
Rob
« Reply #2 on: July 08, 2016, 09:48:37 am »
Thanks Rob for taking the time to reply, I will have another play with it !
Regards   Steve
