Author Topic: Top Mounts help  (Read 1541 times)
Offline fazi123
Top Mounts help
« on: July 09, 2016, 10:50:26 pm »
Hi Guys,
I'm going to be purchasing some coilovers in the coming weeks and I wanted to renew/refresh the top mounts while I was at it.
Could anybody confirm which top mounts both front and rear I could upgrade to? I hear the RS3 / TT mounts are a good upgrade. Can anybody confirm the part numbers or just which model car I should be searching for when looking online?
Thanks in advance,
Faz
« Last Edit: July 10, 2016, 10:45:49 pm by fazi123 »
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: Top Mounts help
« Reply #1 on: July 10, 2016, 09:06:22 am »
If you aren't fused about adjustable top mounts, then yeah RS3 is probably best option.
I have everything needed still in packaging for the front if you want to buy them from me, as I'm getting adjustable ones, so have no need for the RS3 ones anymore.
If you want adjustable top mounts, then you need to look at VWR or Ground Control top mounts.
Offline fazi123
Re: Top Mounts help
« Reply #2 on: July 10, 2016, 09:52:05 am »
Cheers mate. How much are you after for your setup?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Top Mounts help
« Reply #3 on: July 10, 2016, 10:43:52 am »
Sorry to hijack the thread @fazi123  :drinking:
Just wanted to know what part numbers they are please?. @Adam0604
Offline Adam0604
Re: Top Mounts help
« Reply #4 on: July 10, 2016, 09:58:22 pm »
Part numbers:
8J0 412 331 - Strut Mount x2
6N0 412 249 C - Bearing x2
N 910 216 01 - Nut x2
N 101 277 07 - Bolt x6
£75 for the lot @fazi123  ?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Top Mounts help
« Reply #5 on: July 10, 2016, 10:02:08 pm »
If he doesn't want them I'm here  :jumping: @Adam0604
Offline fazi123
Re: Top Mounts help
« Reply #6 on: July 10, 2016, 10:44:37 pm »
Part numbers:
Cheers @Adam0604
Can you hold onto until Wednesday for me? I want to find out from a cousin of mine about whether I should go with the adjustable variants or not.
Thanks in advance,
Faz
Offline Adam0604
Re: Top Mounts help
« Reply #7 on: July 10, 2016, 10:52:50 pm »
Yeah not a problem.
Offline wrlcs
Re: Top Mounts help
« Reply #8 on: July 11, 2016, 09:26:58 am »
Hi, is it an advantage to change to RS3 top mounts at the rear as well as at the front?
Brendan
Offline fazi123
Re: Top Mounts help
« Reply #9 on: July 12, 2016, 02:04:56 pm »
@Adam0604 did you get my PM bud?
