Author Topic: Rev G DV Obsolete?  (Read 7157 times)
Offline PatchySan
  • -Receive: 59
  • Gracie!
Rev G DV Obsolete?
« on: July 11, 2016, 01:56:43 pm »
Hi All,
Just got my 2005 MK5 GTI on the weekend and am loving it. Doing a maintenance check over so went to the dealer to get some key parts - mainly the cam follower and Diverter Valve.
I heard Revision G of the Diverter Valve is the better unit but the dealer told me they stopped issuing those and are giving me a different part number - 06H 145 710 D. Just wondering if this is as good as the Rev G DV or should I consider shopping elsewhere for it? Any tips would be appreciated - thanks!
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Rev G DV Obsolete?
« Reply #1 on: July 11, 2016, 02:31:42 pm »
D is the older part number, G being the newer one. They are fobbing you off, probably trying to sell off their old stock.
I'd consider upgrading to a GFB DV+ rather than a G that will split again in time, or a D that leaks
I actually have a brand new G at home. Should really get round to advertising it as I went GFB DV+
« Last Edit: July 11, 2016, 02:57:46 pm by Dan_FR »
Offline shoaybmakda
  • -Receive: 54
« Reply #2 on: July 11, 2016, 03:23:53 pm »
@Dan_FR how much are you looking for it?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: July 11, 2016, 03:32:42 pm »
Isn't the Rev D the spring type valve and rev G went back to a better quality diaphragm?
Rev D can't split because it's a spring and not a diaphragm but some people believe it holds less boost although there's no studies to back this up.
If you're shelling out for a new one then just up the money and upgrade. If you don't care too much, opt for rev D.
Offline Madone
  • -Receive: 27
« Reply #4 on: July 11, 2016, 04:21:15 pm »
I had a D, leaked boost from brand new, this was in a stage 2+ car, so guess it would be OK at standard boost. I run the GFP like Dan, much better design and will def hold all the boost you can throw at it !
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #5 on: July 11, 2016, 04:23:08 pm »
D is the piston type, They do leak! Niki at R-Tech swears by the Rev G, I fitted the Rev G on 3 x TFSI's now with no issues.
Offline Madone
  • -Receive: 27
« Reply #6 on: July 11, 2016, 04:25:49 pm »
The annoying thing is I had a load of work done by a mate who is a master tech at audi, gave him the part number of the Rev G, never thought to check till last week when I notice the boost was lower than expected. Turns out his parts department gave him a D as it was newer. So I had been running a D for a while !
Offline PatchySan
  • -Receive: 59
  • Gracie!
« Reply #7 on: July 11, 2016, 04:53:17 pm »
Cheers all for the replies, I will have a look at the GFB DV+ instead. Anyone can recommend a good retailer for these?
Offline Madone
  • -Receive: 27
« Reply #8 on: July 11, 2016, 04:55:45 pm »
AwesomeGTI seemed OK for me
Offline raz469
« Reply #9 on: July 11, 2016, 06:04:33 pm »
No faults buying it from amd@ebay.
« Reply #10 on: July 11, 2016, 06:06:16 pm »
AKS Tuning
PSI Tuning
AMD Technik
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #11 on: July 11, 2016, 06:07:48 pm »
I got mine from AMD ebay no problems here
Offline bad devotions
  • -Given: 19
« Reply #12 on: July 12, 2016, 06:42:51 am »
Same here
Sent from my Nexus 5 using Tapatalk
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #13 on: July 12, 2016, 08:20:43 am »
Not to doubt you but from what I've seen, this is only hearsay. Not one study has been carried out swapping out a D for a G and measuring boost accurately across both.
You have a link to info? Genuinely interested as I've bought and fitted both and couldn't distinguish!
Offline Chris92
  • -Given: 33
« Reply #14 on: July 12, 2016, 08:35:35 am »
The last I read about those DV+ things is that they had some issues and leaked to from memory. This is going back a while. Take it they fixed what ever was wrong?
