Author Topic: GFB DV+ Question  (Read 1149 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
GFB DV+ Question
« on: July 19, 2016, 12:53:56 pm »
Since you fit the GFB DV+ to the original diverter valve housing, does it matter if you fit it to the rev D piston type or the rev G diaphragm type?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: GFB DV+ Question
« Reply #1 on: July 19, 2016, 12:55:00 pm »
No. Same solenoid.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: July 19, 2016, 12:58:12 pm »
Thanks!
I'll stick with rev D so...
Next question if you know, without a boost gauge (but I do have VCDS) is there any way I can measure my boost on the current rev D before fitting the GFB DV+ so as I can compare?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: July 19, 2016, 02:10:49 pm »
You can use VCDS to make some logs of the boost pressure. :smiley:
Here's one guide that you can follow: https://www.goapr.com/support/datalogging.php.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: July 19, 2016, 02:15:57 pm »
Perfect! Thanks @shoduchi
Any idea what range of boost I should be logging completely stock?
Offline Pesky jones
« Reply #5 on: July 19, 2016, 02:44:33 pm »
@lukemk5gti peak around 12 psi
P.S does this mean you're starting to go down the non-oem modifying route?  :laugh:
« Last Edit: July 19, 2016, 02:46:16 pm by Peskyjones »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: July 19, 2016, 03:26:27 pm »
Haha not just yet, going to keep her standard but I just want to update a few bits now so that down the line if I choose to I can do without much layout!
Offline bad devotions
  • -Given: 19
« Reply #7 on: July 19, 2016, 04:47:35 pm »
don't believe a word of it... he'll be getting led rear lights soon :P
