Author Topic: Which brand of water pump?  (Read 2610 times)
Offline oisinc
« on: July 19, 2016, 04:22:11 pm »
I need to buy a water pump as the timing belt kit I have ordered is without one.
Which brand is best and should I look for metal impellers only?
TIA
Oisin
Offline Chris92
  • -Given: 33
Re: Which brand of water pump?
« Reply #1 on: July 19, 2016, 06:44:17 pm »
When I did my timing belt I order a hepo one from ecps and it had a metal impeller.
Offline oisinc
« Reply #2 on: July 19, 2016, 10:39:08 pm »
Thanks  :happy2:
Ill make sure the one I have has a metal impeller. Ill prob go with Vaico. I believe their OE manufacturers.
Offline Chris92
  • -Given: 33
« Reply #3 on: July 19, 2016, 10:45:33 pm »
Not a clue what brand vw use from the factory, every time I change one I either forget to look or can't see any stampings on it
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: July 20, 2016, 07:38:15 am »
Don't get one with a metal impeller. Manufacturers use plastic for a reason.
Buy genuine from VW, they are not that expensive on exchange for your old one. I've bought cheap on these engines and had to replace it as it leaked from new
Offline flashp
  • -Receive: 65
« Reply #5 on: July 20, 2016, 10:23:12 am »
I'd echo this.
Keep up with correct servicing and you'll never have a problem.
Gone but not forgotten :-)
Offline Stupots
  • -Given: 18
« Reply #6 on: July 20, 2016, 11:24:53 am »
I believe the reason is, if the metal impeller seizes, it will strip the cambelt... bad
Earlier plastic impellers were prone to disintegrating, but this hasn't been an issue for a while, so go plastic.
Offline oisinc
« Reply #7 on: July 20, 2016, 04:39:02 pm »
ok thanks.. I thought the metal impeller was the preferred option.
Great info on here as always!  :happy2:
Offline slimjimvw
« Reply #8 on: August 04, 2016, 08:14:46 pm »
Buy genuine,  not that expensive comparatively.
Sent from my D6603 using Tapatalk
