Author Topic: How long does it take your air con to start working on your MK5 GTI?  (Read 4662 times)
Offline ghuk
Hi guys
I know its been ridiculously hot today but my air con took almost the whole of the journey home (15 mins) to start blowing cold air through the vents. It's a little strange as this morning it started working almost straight away. I've owned many cars over the years (Jag X Type, Honda Civic, VW Bora TDI, Peugeot 206 GTI) with air con fitted but this is the first time I've come across this problem.
Anyway I've had my Golf GTI just over 1 year now and I did notice this when I was purchasing the car. The garage had the system re-gassed so unless either there's a leak or they down-right lied and didn't bother getting it sorted I'm sure that's not the problem.
Any advice you can throw my way would be much appreciated before I open my wallet  :doh:
George
2005 Golf GTI Mk5
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: How long does it take your air con to start working on your MK5 GTI?
« Reply #1 on: July 19, 2016, 07:48:56 pm »
Might be worth taking it for a regas / oiling... I'm sure there's loads of offers on at the moment from the big suppliers and they won't charge if the system isn't better after... :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: July 19, 2016, 08:15:36 pm »
You need a regas.
mines works but not to its full potential and works within 20 seconds if that so going to regas it at work on Saturday as I know it's not been done for a good few years at least.
Offline ghuk
« Reply #3 on: July 19, 2016, 08:24:18 pm »
Cheers guys
I will get it booked in for a re-gas. Hopefully that will solve the issue  :smiley:
« Last Edit: July 19, 2016, 08:44:19 pm by ghuk »
2005 Golf GTI Mk5
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #4 on: July 19, 2016, 08:32:17 pm »
I regassed mine today and worked within about 20 seconds like r5ggt said
« Last Edit: July 19, 2016, 09:36:42 pm by TAPPY »
Offline Lewo
« Reply #5 on: July 19, 2016, 09:11:48 pm »
Maybe mine need re-gassing too then, takes a couple of mins to run cold?
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #6 on: July 19, 2016, 10:08:56 pm »
Mine was pretty quick today given the heat. Was regassed last year, had a new sensor within the last two (as it had gone porous), and I know the compressor was replaced under warranty before my ownership. Was bliss driving home after the crunking work aircon 'tripped out' - which it always seems to when it is hotter or colder than usual!
Long answer to a short question - yes, mine was cooling within about 20 seconds. Was making plenty of noise as it adjusted the various flaps in the dash, but guess that was all the vents and such being set. It's a noisy system, that's for sure...
Edition 30 - no. 1387
Offline white91
« Reply #7 on: July 19, 2016, 10:48:30 pm »
Mine takes a while to get cold, even though I've had a new compressor and condenser within the last 2 months.
Sitting in traffic makes air con work very hard
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: July 19, 2016, 11:02:00 pm »
Maybe the dryers faulty as it should get cold very quickly and stay cold until you turn it off.
Offline Kai96
« Reply #9 on: July 20, 2016, 12:02:30 am »
Mine works instantly but it smells really bad. Does anybody know what can cause this ?
Offline Juliand
« Reply #10 on: July 20, 2016, 09:41:34 am »
Bacteria in the system - that's why it's suggested that the A/C is used at least once every week - even in winter.
I think if you get an A/C service, they will top up and put some type of de-odorising compound in.
Try Groupon to see what deals are about in your local area. Needs doing every couple of years
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #11 on: July 20, 2016, 05:44:50 pm »
Think my aircon gave up on me in the heights of yesterdays heat. Blower was just blasting warm air and it sounded like Darth Vader. Hope its just a re-gass job and not a new compressor.
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: July 20, 2016, 07:02:52 pm »
My sisters honda gave up the ghost after she had it regas dedicated by Mark in Birmingham great Barr so she had to go back for his to check it and found its got a leak and in need of repair. £175
Offline grey golfster
  • -Given: 79
« Reply #13 on: July 20, 2016, 07:19:12 pm »
I have used this Normfest stuff from ECP for several years in different cars - it does the trick if you follow instructions properly
Product Code: NOR2897300100
Normfest Viro One Shot Plus A/C Treatment 100mlProduct Code: NOR2897300100
£ 5.99
Normfest Viro is a powerful anti bacterial cleaning agent, which when dispersed travels through your entire AC system cleaning and killing harmful bacteria. Easy To use simply;
•Open the packaging
•Use provided box to hold can upright
•Start Engine, Close all windows and turn OFF the AC - Turn ON the Air Recirculation - Set the fans to full power (on cold temperature)
•Press the button on the can to start the dispersal of the gas
•Exit vehicle and ensure all doors are closed
leave it run for 15 mins or so...
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: July 20, 2016, 07:25:13 pm »
I used to use a treatment in my last employment and with that one you leave the Aircon running full  Windows closed exit the car and leave running for 10-15mins.
