Author Topic: URGENT and Dillema with subframe bushes  (Read 7490 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: July 20, 2016, 10:22:23 am »
Hi all,
Does anyone know if there's a special tool to fit the subframe upper and lower bushes as ive tried to fit them and when going in the bush starts to bow on the weakest point and stops it from going in?.
Offline raz469
« Reply #1 on: July 20, 2016, 10:42:45 am »
Got my subframe mount done yesterday mate. Tops going in today! Yay!!
The lower mount was a pain. Literally took 2-3 hours to get it in.
In the end we had to get a g clamp/ monkey grips squeezing the bow and push mount in. That being said mine was oem and had a plastic outer.
Didn't look nice, but feels so great now.
« Last Edit: July 20, 2016, 10:52:26 am by raz469 »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: URGENT and Dillema with subframe bushes
« Reply #2 on: July 20, 2016, 11:09:15 am »
That's the problem I'm having  :sad1:
Offline raz469
« Reply #3 on: July 20, 2016, 11:13:47 am »
The mechanic just told me, theres a widget you can get to insert into the dogbone cutout and you can get a cone to help the lower go in.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: July 20, 2016, 11:31:27 am »
Thanks bro my company are being f**kers and being cheap saying there's no special took but I'm certain there is. can you get any part numbers for the tool please?.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: July 20, 2016, 01:29:12 pm »
I donr recommend anyone try this at home or you'll be stuck up the creek with no paddle  :surprised:
Nightmare of a job and there are special tools for this job.
Offline raz469
« Reply #6 on: July 20, 2016, 04:13:58 pm »
Sorry dude but don't have a pn for it. Just what the guy said. Tried calling vw or a specialist vw fitters?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: July 20, 2016, 06:15:56 pm »
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: July 22, 2016, 02:06:05 pm »
The trick is to insert a pry bar between the subframe and the part of the bush that bows.  Lever the bush in while pressing down.  Takes around 20 mins to get the bushes pressed in.
Follow AKS tuning on Facebook
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: July 22, 2016, 06:18:36 pm »
Where were you when I was desperate  :doh:  :signLOL:
Tried thay and snapped a bush  :slap:
In the end I used the press to press down and a huge pair of grips that someone else was griping as I don't have the strength for that. theres always one beech out the lot and I got it.
@vRSAlex don't you use the special tool vag have?.
« Last Edit: July 22, 2016, 08:15:52 pm by r5gtt »
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: July 23, 2016, 02:19:22 pm »
Hadn't ben on the forum much so missed the question  :sad1:
Got the fitting of them sussed a fair few years back and don't do enough to bother buying the tool.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: July 23, 2016, 05:38:50 pm »
Yeah I did notice you've been quiet  :signLOL: Yeah not many people have then fitted but my job entails me to do so when replacing the subframe  :sad1: pain in the  :booty: if you also me and a stupid design from VAG.
I'll be doing mine soon but have the Vibratechnics pair so should go straight in he says  :scared:
Thanks again for your reply  :drinking:
MPS
« Reply #12 on: January 27, 2017, 12:45:59 pm »
Bit of a thread revival but this is the best aftermarket tool to do the job, makes it a doddle. Not cheap but much cheaper than the official workshop tool and easier as removal of the subframe is not required. The trick is finding a garage who aren't cheapskates and actually have this tool. [Best bet would be to find a reputable VAG specialist in your local area.]
« Last Edit: January 27, 2017, 12:49:22 pm by MPS »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: January 27, 2017, 06:15:30 pm »
thank you for your link and message @MPS
Yes it looks stupidly simple with that set as I did those on the A1 and had to grind the edges for them to go on and also a huge set of water grips and a strong guy to help me with them. If I had a another garage is invest in this myself.
People say it's easy but I don't believe this as the part that bows does snap!!!
Thanks again mate  :drinking:
MPS
« Reply #14 on: January 28, 2017, 10:55:59 pm »
