Author Topic: SuperPro adjustable ball joints  (Read 1792 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« on: July 23, 2016, 04:18:34 pm »
I had the SuperPro adjustable ball joints fitted to my Ed. 30 recently but unfortunately the ball joints rub the discs of my Brembo 18Z kit when I make hard turns. The ball joints were cut twice, the dust shields were cut to make a window just were the ball joints would rub, but even after putting the camber as positive as possible they keep rubbing on hard cornering. :sad1:
My mechanic is against cutting the ball joints more so the only option I have now is to return to stock ball joints. Has anyone any experience with these ball joints and BBK?  :thinking:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3efsh4t6tvjq3fvd6i89jqfiub&/topic,19740.0.html
Re: SuperPro adjustable ball joints
« Reply #1 on: July 24, 2016, 12:43:09 am »
Yep. Sometimes they are not compatible with certain rotors. Just remove them. The amount of camber they give isn't that much anyway.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: July 24, 2016, 01:52:26 am »
Thanks @rich83. I'll have to live with stock camber since I'm not fitting camber plates or coilovers with camber adjustment. :sad1:
