Author Topic: Intermittent cruise control  (Read 2618 times)
Offline Gmac
  • -Given: 30
« on: July 25, 2016, 03:02:27 pm »
Afternoon all!
Have a bit of a weird one.... My cruise control green light on the dash every now and then disappears, meaning I lose cruise control!
Normally a quick turn off then on, of the ignition and the light comes back on, although not all the time and sometimes it takes a few attempts!
I've been trying to figure out if something is triggering it and it seems to possibly be linked to when I operate the indicators! especially the right hand one!!
What's going on here?? And any suggestions as to how to cure the problem?
TIA
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Intermittent cruise control
« Reply #1 on: July 25, 2016, 03:31:58 pm »
Could be a dodgy stalk.
Check with VCDS.
Offline mo
« Reply #2 on: July 25, 2016, 04:00:45 pm »
I have this same issue.Had mine fitted about a year ago and its been acting up over the last month or so.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline laral
« Reply #3 on: July 25, 2016, 04:12:15 pm »
I had the same problem took stalk apart and it was a broken wire which I repaired and no more issues. The wire was over works I work-related it used some extra heatsink to stop it rubbing through
Offline laral
« Reply #4 on: July 25, 2016, 04:16:30 pm »
Fixed stupid predictive text
I had the same problem took stalk apart and it was a broken wire which I repaired and no more issues. The wire was over plastic and wore through it I used some extra heatsink to stop it rubbing through again
Offline Gmac
  • -Given: 30
« Reply #5 on: July 25, 2016, 07:44:22 pm »
Thanks for the replies folks,  do i need to take the steering wheel off to get the stalk out and look at any potential wiring issue? :happy2:
Offline laral
« Reply #6 on: July 25, 2016, 08:09:17 pm »
Sadly I had to and remove the stalk for the repair but wasn't to bad as far as I remember it was a red wire but was obvisiously broken when able to get access
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bgp894qrb48qddv38vfd2b1bau&/topic,19740.0.html
« Reply #7 on: July 25, 2016, 08:14:37 pm »
Ive had 2 mk5 golfs and about 4 CC stalks!  :signLOL:
Offline andy7ven
  • -Receive: 30
« Reply #8 on: July 25, 2016, 08:35:05 pm »
I don't think mines ever worked!!!
I click the switch over the light comes on the dash but ain't got a clue how to set the speed?   :stupid:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: July 25, 2016, 09:01:17 pm »
Hold the button on the stalk down and it should set. you can also go up with speed and down when pressing the up down buttons. mine works but when I press the brakes it goes into normal mode BUT on the odd occasion it will automatically go back to the set speed randomly  :signLOL:
Offline andy7ven
  • -Receive: 30
« Reply #10 on: July 25, 2016, 09:24:21 pm »
 :scared:  Thanks mate i'll give it a try next time on the motorway  :happy2:
