Author Topic: Need help with xenon wiring  (Read 3264 times)
Offline Scoobykiller
« on: July 25, 2016, 03:12:14 pm »
Hey
Need help wiring the xenon adaptor yellow wire to ccm for retro fit
Exactly where do i have to join them wires
Thank you
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Need help with xenon wiring
« Reply #1 on: July 25, 2016, 03:55:23 pm »
Plug A pin 5, Plug D pin 6
Sent from my SM-G928F using Tapatalk
« Reply #2 on: July 25, 2016, 04:44:42 pm »
Do i just tap the wires into the previous wires isnt there any tutorial with photos as i dont know which is plug and pin number etc
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: July 25, 2016, 05:18:17 pm »
On the cecm it will say what plug is what, they are all labelled. You take off the correct one. A and D. And remove the pink locking plastic, find pin 5 on plug A, it will be empty, plug the wire in. Do the same for D6.  Put the locking plastic back in, pop the plugs back into cecm and check xenons with shutters in vcds. Job done. I'll find u the guide too
Offline sbhachu
« Reply #5 on: September 11, 2016, 10:41:50 am »
On the headlight adapters, I noticed my extra wires to CECM don't have the pin connectors on the end of them. Do I have to buy them. What size do I need?
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #6 on: September 11, 2016, 12:35:14 pm »
Strange - did you buy new or did someone badly rip them out from a previous install? You will need to create pins for the ends of the wire.
Offline sbhachu
« Reply #7 on: September 11, 2016, 12:59:30 pm »
Yes strange. The ones I have look brand new, have vw stamps on each of the plugs and have rubber grommets to prevent water entering in. The additional wire is green not yellow on mine but does not look like it's been cut.
Thanks for showing the other picture. Can I crimp on the connector, what size would I need and where would I get it from?
Charlie23
« Reply #8 on: September 14, 2016, 12:46:27 pm »
Could i ask a question??
What are you wiring them in for? Is it to use the leveling etc etc?  :thinking:
Sorry if this sounds abit stupid  :laugh:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: September 14, 2016, 12:47:59 pm »
for shutters to open and close when flashing to pass
Charlie23
« Reply #10 on: September 14, 2016, 04:33:49 pm »
Thats what i was hoping you was going to say ha-ha.  :grin:
Just i replaced my candle power lights for xenons last week and i had the exact same plug kit as above but wasnt intrested much in having the shutters working so chopped the wire and tidyed it all up.
Have you had to use Vag Com at all to program them or anything?  :happy2:
Offline Rossimac
  • -Given: 78
« Reply #11 on: September 15, 2016, 11:07:39 am »
To be honest, you're missing out!
I ran without the shutter wire connected to my cecm for 6 months and I wasn't in a big rush. When I finally got around to it and lit up a B road, I was very happy with the result! Everything is lit up, I can barely drive with a halogen car now...
Charlie23
« Reply #12 on: September 21, 2016, 12:48:17 am »
Hahahaha  :happy2:
I had bixenons on my S3 and I only used them to pretend I was a police car and pull people over  :stupid: :doh: (did actually work to)
