Hi all,
Just fit my shiny new vz033's and it's highlighted even more the need to lower the stance slightly.
However, as I use the car to go mountainbiking it often has 2 fairly hefty (+/- 35lb) downhill bikes in the back + kit + Typically driving hard on bumpy Welsh b roads, so what I really don't want to happen is any rubbing, especially with the slightly wider offset of these wheels.
I also do a couple of trips a year at least to the Alps with the car fully loaded, and driving fairly hard up/down steep hills.
Anybody with these wheels or similar size / offset who has experience with / avoiding rubbing when loaded up, I'd be glad to hear your thoughts!!
Top of the list so far is the VWR 20mm spring, plus I need geometry etc. doing as I've been getting premature wear on the front inner edges.
thanks
ed
